Daz, it should be a straightforward job but can be a right pain in the chuff if things get stuck fast....
Plenum & injectors off to reveal the top of the oil cooler and the stat housing at the front. Bucket ready to catch dropped coolant if clean and fresh. If not, you need new. The b*rst*rd bold referred to is the one which holds the dipstick, engine lifting lug and transfer pipe onto the passenger side of the engine. Remove that but leave the water hose connected as well as the two torx keeping the stat housing onto the block top.
The transfer pipe is a push fit into the stat housing but can need a fair bit of wriggling/pulling/twisting to get it to pop free. Once its free, remove hose, remove transfer pipe and stat torx bolts and pop off stat housing.
There were, I think, 5 different sets of hands trying to release the pipe on Kates car at the cambelt doo and all to no avail. It all went the shape of the pear when a lever was introduced to try to force it out and we broke the locating lug from the transfer pipe. At that stage, it was broken beyond repair and so was then removed by means of a chisel and lump hammer.
Once out, it was found there was no stat within the housing.
Fortunately, issunaz had a spare housing and pipe so it was all reassembled. It was decided by those more cleverer than what I is that the two seals between the pipe and housing could be reused. Trust me, its worth replacing them to save having to part strip it all back down again when the engine bits are all chuffin hot....
Reassembly is, in the best Haynes tradition, reverse of removal. Remember to use enough coolant to bring the mix back to 50/50.
As said, should be a straightforward job but be prepared for a real challenge! It took 4 or 5 hours, I think, to do Kates at the doo last month.....
