Pages: 1 2 [All]   Go Down
Author Topic: P0340 Cam sensor code after belt change  (Read 3572 times)
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
« on: 25 September 2019, 14:52:11 »
I'm depressed at the moment.  :-\ :'(
Had everything back together and firing it up and it ran really bad, not on all cylinders. Engine turn over and no mechanical sounds and sounds Ok until it fires upg, just running bad.
Got code P0340 and a P0300 (Misfiring) which it does.
The cam belt was properly aligned and it turned over OK when I checked the belt timing and it looked perfectly OK.
The cam sensor connector is connected.
What could be wrong? It ran perfectly fine before I started this job.
I'm a bit tired now after this and a few other things I've done to it the last days.
One thing during the belt change was that I had to remove the locks to get it on the belt correctly. It was off a bit. I held the cam with a ratchet wrench which was stupid. So it went away. I did turn it back to its position but could it really turn a complete 360° wrong. I mean it did stop and I could only turn it back to its proper position. Valves was hitting and it stop there. During this the crank was in position. It was cam 1 and 2 I had to do this on.
If it got completely wrong it wouldn't turn over, right?
Jan Suhr
Stockholm, Sweden
www.protouring.se
jonathanh
  • coventry
Re: P0340 Cam sensor code after belt change
« Reply #1 on: 25 September 2019, 15:38:53 »
Are you sure you have aligned the right cam markings for each cam? As far as I remember each sprite to has two and it is vital to align the correct one given your cams slipped when the locks were removed?  I’d need to look up which mark on which cam to be sure what’s right but someone else here may know
parking near Birmingham airport for members with +250 posts.  PM for info
« Reply #2 on: 25 September 2019, 16:00:23 »
Coil packs fully plugged in?
Jan Suhr
  • Nyköping, Sweden
« Reply #3 on: 25 September 2019, 16:01:53 »
Yes I saw that. I have aligned them to the mark that is close to the number.
The code says: P0340 Camshaft position Sensor A Circuit Bank 1 or Single Sensor
Jan Suhr
Stockholm, Sweden
www.protouring.se
Jan Suhr
  • Nyköping, Sweden
« Reply #4 on: 25 September 2019, 16:02:22 »
Haven't touched them
Jan Suhr
Stockholm, Sweden
www.protouring.se
« Reply #5 on: 25 September 2019, 16:03:10 »
Cam sensor wire pinched by the cover?
Also possible to swap it with the knock sensor plug as they are adjacent on the loom
Jan Suhr
  • Nyköping, Sweden
« Reply #6 on: 25 September 2019, 16:11:22 »
Those are on the left side of the engine, right? I haven't touched them. The code says bank 1 so that is on the right side. There are two cam sensors on the V6?. If so I might have pinched the cable when I mounted the utility belt tensioner. The cable was a little tight when I was connecting it to the harness.
Jan Suhr
Stockholm, Sweden
www.protouring.se
« Reply #7 on: 25 September 2019, 16:35:04 »
Only one cam sensor, sits on the front of the 246 head, and works off cam 4 iirc :-\
Jan Suhr
  • Nyköping, Sweden
« Reply #8 on: 25 September 2019, 16:48:20 »
OK.
If you look at this image and on the 4th cam. This is how it was before I took it apart.
The two marks on the  4th cam seems to use the right mark and on cam 3 it uses the left mark. I think i set cam 4 to the left mark when I set them up after they broke loose.  If so then it must explain what is wrong here.
Back at it then...
Jan Suhr
Stockholm, Sweden
www.protouring.se
« Reply #9 on: 25 September 2019, 17:06:55 »
Use the locking kit NOT the marks :o
Those back plate marks exist purely to give something to aim at on the production line, nothing more. Even then the timing is done with a locking kit.
jonathanh
  • coventry
« Reply #10 on: 25 September 2019, 17:20:48 »
Agreed use the locking kit but you’ve got to know which mark you are lining up
To the op bear with me and i’ll Try to fish out which marks are the right ones to use
« Reply #11 on: 25 September 2019, 17:28:00 »
There's a timing tool in the locking kit for that very purpose
Jan Suhr
  • Nyköping, Sweden
« Reply #12 on: 25 September 2019, 17:35:06 »
I'm talking about the marks on the cam wheels, as there are two marks on each wheel and I suspect I used the wrong mark on the cam 4 wheel when I was putting it back in position after it went loose and turned anti-clockwise a bit.
If I compare how the marks are positioned on it before I took it apart I didn't position the 4th wheel in the same position as it was from the start.
And Yes of course I use the proper tools for aligning.
Jan Suhr
Stockholm, Sweden
www.protouring.se
Jan Suhr
  • Nyköping, Sweden
« Reply #13 on: 25 September 2019, 17:50:28 »
This image shows the marks at the red arrows as the correct ones. OK, it is not in proper position on this image, I hadn't started working on it yet.
When it went loose I aligned cam 4 to the green arrow in relation to cam 3, this must be the cause of my problem. Cam 4 is running a little ahead and will give the P0340 error.
Jan Suhr
Stockholm, Sweden
www.protouring.se
jonathanh
  • coventry
« Reply #14 on: 25 September 2019, 18:14:36 »
On the left hand cam use marking 3 the red one you have marked. On right hand cam use mark 4 the red one not the green.  It would be good for someone else to confirm too as I am going from memory- last time I changed a belt was two years ago!!!
« Reply #15 on: 25 September 2019, 18:45:43 »
They are numbered 1 through 4 according to the cam position  ;)
1 and 4 are the exhaust ones, and 2 and 3 are the inlet ones ;)
Jan Suhr
  • Nyköping, Sweden
« Reply #16 on: 25 September 2019, 18:50:24 »
I agree, the picture shows the correct position with the red arrows since this was before I took it apart. The tricky bit that fooled me is that the wheels 3 & 4 are the same. On wheel 3 there are the numbers 3 4 stamped at the left mark, and that's why I positioned it at the green arrow since the numbers are there. Whey they did so is a bit unlogical in my mind. But maybe the 4 had to be where it is since there is a big hole where it supposed to be.
Anyway I correct this tomorrow and let you know if it works better after that.
Jan Suhr
Stockholm, Sweden
www.protouring.se
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #17 on: 25 September 2019, 20:42:29 »
Cam 3 is the long notch and cam 4 is the short notch, so the red arrows are correct as said.  :y
Jan Suhr
  • Nyköping, Sweden
« Reply #18 on: 26 September 2019, 14:57:40 »
Now the cams are properly set and the engine runs and sounds like it should.
Feeling good again  :)
Jan Suhr
Stockholm, Sweden
www.protouring.se
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« Reply #19 on: 30 September 2019, 14:55:39 »
Good that solved, is the belt more "in front" now? Remember I thought it was a bit back.
Jan Suhr
  • Nyköping, Sweden
« Reply #20 on: 30 September 2019, 15:16:53 »
Yes thanks for asking,
Everything in order and proper alignment. The belt runs good on the idlers. The old kit wasn't the correct one for this engine. It had the earlier kit and it should have the later. I expect it to last 60000km as  it should. This is my winter car, instead of changing tyres I swap cars  ;D
When it's duties is over in the spring I will check the status on the cam belt.
Jan Suhr
Stockholm, Sweden
www.protouring.se
polilara
  • Finland
« Reply #21 on: 30 September 2019, 17:46:28 »
OK, hope you have spikes and LSD, some snow will come soon...
Pages: 1 2 [All]   Go Up
Page created in 0.02 seconds with 18 queries.
