It's streath bolt so ones you grind head off you take tension of bolt
Simple as that
I find gas torch do job every time , new bolt only cost £6 from Gm
Two way's of looking at that :
1 : There is no such thing as a stretch bolt - it's a normal bolt that has been tightened past yield.
2 : All bolts are stretch bolts - if you tighten any bolt past yield they will stretch permanently.
If you cut the head off any bolt you will relieve the tension in the shank which should make it easier to remove - provided it hasn't been Loktite-ed or rusted/corroded in.
Stretch bolt is a misnomer for a bolt where the manufactures installation spec deliberately takes the bolt past yield, and is usually identified by a tightening spec of X Nm + Y Degrees. It is unwise to re-use a bolt that has been tightened past yield.
