Pages: 1 2 3 [All]   Go Down
Author Topic: Aircon Compressor Clutch  (Read 4547 times)
« on: 03 August 2013, 15:14:06 »
Got the aircon regassed, but the compressor clutch isn't engaging... :'(
0v going to the compressor, so where to be looking for the culprit :-\
Re: Aircon Compressor Clutch
« Reply #1 on: 03 August 2013, 16:24:12 »
Clutch engages when connected direct to battery, aircon working as expected, which is a start :-\
Fuses 12, 14 and 15 ok as well :-\ have swapped the relay with both the horn one and K87. No change, all three relays work on the horn circuit, so confident that I have ruled out that problem.
Every thing else (according to the book of blocks) seems to point to the engine ecu or wiring to the relay :-\
« Reply #2 on: 03 August 2013, 16:49:04 »
Might be a coincidence, but the coolant pump on the radiator has just gone up in smoke :o
When compressor connected direct to battery...
1. Front fans run constantly.
2. Second stage fan in the cabin air intake runs.
3. Main fan cuts in/out as expected from the gauge.
Plug compressor relay in, and 1. and 2. both cut out instantly, 3. stays the same.
What is likely to happen with the clutch permanently engaged, even when engine off?
  • Online Online
« Reply #3 on: 03 August 2013, 16:49:40 »
... or wiring to the relay :-\
At some point before I owned the car, the wiring underneath my battery had been 'modified' by Vauxhall. I've the receipt for it somewhere.
Any use?  :-\  :-\  :-\
« Reply #4 on: 03 August 2013, 17:08:50 »
All looks to be in order under there :-\
That looks like I soldered it ::)
Front fans do come on with the compressor off, but only after the rear fan which I believe is normal when aircon off...
RobG
    • 16 plate Mokka. Vivaro
« Reply #5 on: 03 August 2013, 17:27:29 »
Faulty low pressure switch :-\
« Reply #6 on: 03 August 2013, 17:40:07 »
Presumably there are only three things which will tell the ecu not to power the clutch relay...
1. Low pressure.
2. ECO switch on the climate panel.
3. OFF switch on the climate panel.
How reliable are the pressure switches, and are they available separately  :-\
RobG
« Reply #7 on: 03 August 2013, 18:06:23 »
1. Low pressure.
How long`s a piece of string. :) Can be obtained separately :y
« Reply #8 on: 03 August 2013, 18:56:44 »
All the other wiring seems to be behaving as expected. When the clutch is plugged to the battery, the front fans run instantly, and I have disconnected the radiator pump as that's now dead.
Shall try the pressure switch next
Thanks all :y
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
« Reply #9 on: 03 August 2013, 19:00:15 »
low pressure switches are available but cost £58.+ on tc, hence i got a s/hand one from scrappie £2.00.
Hoof'land storeman.
« Reply #10 on: 03 August 2013, 19:11:11 »
Presumably the system will need regassing again ::)
RobG
« Reply #11 on: 03 August 2013, 19:14:47 »
Depends how quick you are with a spanner ;D
« Reply #12 on: 03 August 2013, 19:17:04 »
 ;D
Might only make a small hole in the Ozone layer if I remember to unplug it first :-X
  • Online Online
« Reply #13 on: 03 August 2013, 19:27:01 »
;D
If the a/c specialist is going to re-gas your system afterwards, they'll normally de-gas it for you for free.
« Reply #14 on: 03 August 2013, 19:30:00 »
I try to keep things simple... the machine is much quicker if there's nothing to drain out of it ;D
A valid observation though :y
  • Online Online
« Reply #15 on: 03 August 2013, 19:31:45 »
A good point, well made!  :y  :y  :y  :y
biggriffin
« Reply #16 on: 03 August 2013, 20:56:09 »
o yes,have you got your vx masterfit voucher,if so get vx to do it.
or you could go to (time to get linched) halfruds get a a/c kit using your trade card,(omega uses whole tin) refill with that to check system is working,(take empty back £10 back).
Hoof'land storeman.
sassanach
  • trowbridge
« Reply #17 on: 04 August 2013, 21:54:22 »
I not sure on the ohmygod,but on vectras of the same period you can change the low/high pressure switch's without emptying the system.
« Reply #18 on: 07 August 2013, 00:43:49 »
Shall investigate some more at the weekend :y
« Reply #19 on: 07 August 2013, 10:51:15 »
Before you change anything, try diagnosing the pressure switch (aka triple switch) by bridging the contacts.
From memory, the aircon triple switch is fed a signal from the climate panel which enables air con if the climate panel is calling for cold air. It will break this circuit if the system pressure is below the minimum pressure or above maximum pressure. This wire is colour coded black with a white tracer at the triple switch.
This signal then feeds an input to the engine ECU. If you've got a code reader that shows live data I believe you can read the level of this input from the ECU. Output from the engine ECU feeds the air conditioning relay K60 so the engine ECU can veto the use of air con in certain cnditions.
There is also a coolant temperature switch that breaks the ground connection to the air con compressor if the coolant gets too hot. This would leave the fans operating as normal, so guessing this isn't the problem.
The triple switch also has another contact (Brown / Brown with white tracer) which brings the fans up to full speed at a certain pressure.
I would try bridging the black / white wires into and out of the triple switch next.
« Last Edit: 07 August 2013, 10:52:50 by Kevin Wood »
« Reply #20 on: 07 August 2013, 10:57:09 »
By the way, it's also worth checking fuse 29.
EDIT: and fuse 52 in the engine bay fuse box, considering that pump burnt out, although it will only affect engine cooling and not air con.
« Reply #21 on: 07 August 2013, 21:44:06 »
Thank you for that Kevin :y was thinking along the same lines so that I can refit the relay if nowt else ::)
« Reply #22 on: 08 August 2013, 00:48:52 »
« Reply #23 on: 08 August 2013, 01:08:30 »
biggriffin
« Reply #24 on: 10 August 2013, 16:01:59 »
Well,if you need a compressor.
http://www.ebay.co.uk/itm/330973104057?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
If id have seen that would have had a go, new they cost £150.
 missed a bargin there :'(
Hoof'land storeman.
« Reply #25 on: 11 August 2013, 19:58:51 »
Tried at the switch end. No joy :'(
Bridging the BrWs wires puts the high speed fan on, but only the drivers' side :-\ both front fans run when the clutch is connected directly to the battery, so guess one high speed fan is normal...
Fuses 29 and 52 both fine :y
« Reply #26 on: 12 August 2013, 09:51:01 »
That's weird. I know you can force the ECU output to pull in K60 using a Tech 2. Might be worth a try. I would also try pulling K60 and bridging the pins where its' contacts are. Should enable the compressor clutch and fans.
I think one fan on full speed would be normal in the situation you describe. The other fan requires K60 to be pulled in.
« Reply #27 on: 12 August 2013, 13:38:34 »
Wiring diagram received :y guess the pressure switch is functioning as expected.
K60 not doing anything so guess an issue with the switching feed to that :-\ connect the clutch output to the battery, the front fabs run and clutch engages...
symes
  • oxford
    • R reg 940 volvo
« Reply #28 on: 12 August 2013, 13:46:59 »
not being funny but how is electrical plug connecting air con----mine was smothered in oil and caused all sorts of hassle :y :y
and it can chaff through as its near sharp metal :y
« Reply #29 on: 12 August 2013, 14:53:43 »
K60's feed comes from the engine ECU only a few inches away. What happens if you take the top off K60 and activate the contacts manually?
« Reply #30 on: 12 August 2013, 14:54:56 »
Nothing :-\
Just to add in response to Symes, compressor connection fine :y currently running it with 12v feed from battery direct to clutch output of the relay holder :y
« Last Edit: 12 August 2013, 14:57:41 by ex taxi al »
« Reply #31 on: 13 August 2013, 10:01:37 »
Nothing :-\
That's odd ???
Do you have 12V at pin 30 and 86 of the relay base with the ignition on?
Forgot to say, if you're going to manually operate the relay contacts, ignition needs to be on. :-[
« Reply #32 on: 13 August 2013, 19:08:45 »
Had guessed that much ;D
Nothing between 86 and 30, but my multimeter might be defunct ::) doesn't register a voltage across the battery, let alone a relay ;D
  • Online Online
« Reply #33 on: 13 August 2013, 19:09:41 »
..., but my multimeter might be defunct ::) doesn't register a voltage across the battery, let alone a relay ;D
Ooops!  ;D  :y  :y
« Reply #34 on: 15 August 2013, 18:53:20 »
Have you been using the Amps range and fubared the internal fuse?
Anyway, I was talking about between 86 / 30 and ground. There'll be nothing between them but they should both get an ignition switched feed.
« Reply #35 on: 15 August 2013, 18:59:12 »
Can connect all four terminals together, engine running and nothing happens :-\
« Reply #36 on: 15 August 2013, 20:23:20 »
Ok.. But if you connect pin 86 to 12V the compressor and fans kick in?
Are you sure F29 is OK?
« Reply #37 on: 15 August 2013, 20:32:36 »
Yes to both :y
« Reply #38 on: 24 August 2013, 18:17:41 »
Right progress of sorts :-\
Now if I connect sockets 30 and 87 together, with no relay, the aircon clutch engages, and the fans run when the ignition is switched on. Switch off, all goes off  :y which means I no longer need the direct connection to the battery :)
Relay in and nothing happens :-\
Have yet to try another relay, but previously they all tested working in the horn circuit...
Pages: 1 2 3 [All]   Go Up
Page created in 0.029 seconds with 18 queries.
