Pages: 1 2 [All]   Go Down
Author Topic: Mondeo Cambelt Change  (Read 4562 times)
    • 2 Fords
« on: 06 April 2018, 11:34:56 »
My Ford Mondeo 2.2 TDCi is due a new cambelt and recently my local garage told me it would cost about £250-£350.
The other day I saw an advert for a website that gets quotes for repairs servicing etc, so I thought nothing ventured nothing gained etc and popped in the details of my car and the work required.  :y
I've had one quote back..... from Halfords Autocentres......     £530.91!!  :o :o :o  I don't think so!  ;D
www.MyCarNeedsA.com
Re: Mondeo Cambelt Change
« Reply #1 on: 06 April 2018, 11:51:38 »
My Tata and the mighty Signum both come with a chain. :)......as does the  Corsa.
« Last Edit: 06 April 2018, 11:53:23 by Field Marshal Dr. Opti »
deviator
  • Chesterfield
« Reply #2 on: 06 April 2018, 11:59:26 »
It's nice to see they provide you with towing equipment as standard.  ;)
FCR and cam lock off kit available. Deposit maybe required. Contact me.
« Reply #3 on: 06 April 2018, 11:59:41 »
Why do manufactures use a belt that needs to be 'expensively replaced' every forty thousand miles when a chain 'should' last the life of the car?
« Reply #4 on: 06 April 2018, 12:24:57 »
Modern vauxhalls state 100,000 miles or ten years. People on here will no doubt say that they wouldn't wait that long, but I never keep a car long enough to find out.
    • 2 Fords
« Reply #5 on: 06 April 2018, 12:34:37 »
The Mondeo is 10 years/125,000 miles.  It's an 08 plate and has done about 123500 miles.  :)
So I'm OK for a few months/miles until it self destructs!   ;D
« Reply #6 on: 06 April 2018, 12:40:35 »
.. because a chain isn't compatible with telling people it'll do elevently million miles between oil changes, as they do. ;)
« Reply #7 on: 06 April 2018, 12:42:32 »
If memory serves Vauxhall originally claimed 80,000 miles between cambelt changes for he Omega, which they later revised to 40,000 miles.
« Reply #8 on: 06 April 2018, 12:46:12 »
Yes....oil changes every fifty million miles as prescribed by some manufactures can lead to problems.
Service intervals on cars from the sixties and seventies was often as low as every 3000 miles.
    • 2 Fords
« Reply #9 on: 06 April 2018, 12:52:35 »
Back in the days when a car with 60,000 miles was a high miler!  ::)  :)
« Reply #10 on: 06 April 2018, 12:54:32 »
I think that cars today 'go out of tune' far more slowly than cars of yesteryear.
Carbs have gone.......as have points which would wear and change the timing. I remember seeing the air filter from a Cortina 2000 GXL MK3.
The car was returning about 14 MPG and the filter which was as black as Obama's arse had never been changed. The points were black and pitted, and the plugs which were supposed to be changed each year/12000 miles were wet and black.
Couldn't get it to rev above 3500 RPM. ;D
« Reply #11 on: 06 April 2018, 12:56:28 »
Back in the days when a car with 60,000 miles was a high miler::)  :)
Yep.....a rebore and oversize pistons was quite common on cars at that mileage or less.
TD
  • Swindon
    • Nowt!
« Reply #12 on: 06 April 2018, 12:56:32 »
As my mondeo did at 150k ....  ::)
« Reply #13 on: 06 April 2018, 13:27:34 »
I remember going with a mate to buy a Chevette.  ::) It was in reasonable condition but the engine was as rough as a bear's @rse and the owner clearly clueless. We took a punt on the fact that it just needed some TLC.
I drove it home and it was barely drivable.
We thought we'd go over everything to give it a good service. On removing the rocker cover to adjust the tappets, we couldn't find any. Just a mass of black jelly that wobbled a bit when you started the engine. ;D
The air filter had totally clogged with oil from the breathers, the points were barely opening at all and chunks kept plopping out of the drain plug when we drained the oil.
A new set of filters, plugs, points, oil and coolant change, check the timing and adjust the mixture and it drove like it had just come out of the factory. :y
deviator
  • Chesterfield
« Reply #14 on: 06 April 2018, 13:35:35 »
That bad?  ::)
« Reply #15 on: 06 April 2018, 13:40:24 »
\. ;D
The air filter had totally clogged with oil from the breathers, the points were barely opening at all  :D
Not good.
The last car I owned with points was a 1982 Mark 1 Astra 1300.
There are whole generations of mechanics who have never had to slide a feeler in to see if it is a nice snug fit. ::) :D
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #16 on: 06 April 2018, 13:45:26 »
Oh, I still LOVE to do that, Doctor!  ;D :y
Ron.
« Reply #17 on: 06 April 2018, 14:08:35 »
Ron.
At your age, Ron. :o :o :o :o
« Reply #18 on: 06 April 2018, 14:16:58 »
\. ;D
Not good.
Must have been the 1.2 pushrod, the 1.3 OHC had electronic ignition from day 1 (what a sad git I am)
« Reply #19 on: 06 April 2018, 14:40:37 »
\. ;D
Not good.
It was 'Y' reg estste and badged 1300S. I can still recall the number plate, TNT 85Y. :y
It was finished in a repulsive shade of orange. Deffo had points.
« Last Edit: 06 April 2018, 14:43:45 by Field Marshal Dr. Opti »
« Reply #20 on: 06 April 2018, 15:15:38 »
That bad?  ::)
I wondered if I'd get a bite. ;)
« Reply #21 on: 06 April 2018, 17:43:32 »
The BMW tractor lump when first released was 4500 miles, and that was mid 90s.  Obviously, the marketeers got that changed to double that by the late 90s ;D
« Reply #22 on: 06 April 2018, 17:45:59 »
I'm always happy to go to what the manufacturer states with belts, but start getting nervous when going significantly over.
The Jag is something like 100k on the belts change as well.
ians
  • Reading
« Reply #23 on: 09 April 2018, 10:29:42 »
\. ;D
Not good.
I had one of those.  W Reg finished in a lovely shade of grandad brown.
Actually I loved it but always hankered after a GTE.
Still have the Haynes book somewhere!
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #24 on: 09 April 2018, 11:06:21 »
\. ;D
Not good.
that was the old Opel Kadett engine wasn't it  ???
other rides
  mk3 Volvo v70 2.0 Diesel ,Citroen C2, Pug 306 cabriolet
« Reply #25 on: 09 April 2018, 11:18:38 »
\. ;D
Not good.
My 1.3 Astra was OHC and had points.
ians
  • Reading
« Reply #26 on: 09 April 2018, 12:11:33 »
\. ;D
Not good.
+1
Pages: 1 2 [All]   Go Up
Page created in 0.093 seconds with 21 queries.
