Well job completed today. Were dead at work so boss let me take half day holiday so I cracked on.
So got stat in then transfer pipe (lined up no problem-don’t know what the fuss is all about
) anyway on to sandwich plate. cleaned all twelve bolts with wire wheel and threaded them all in gently by hand. Ten of the bolts including one I thought would struggle all accepted a torque of 20nm. The last two... one threaded in but felt loose. Put a little blue loctite on and it tightened up and I left it be. Final one was simply shagged.... I decided to leave it out. Car runs great 👍👍👍 if it becomes an issue in future I’ll address it but I think 11 bolts holding it in will be fine 👍
After bleeding coolant and checking for leaks and driving home the temps acting exactly as it should but of course will monitor 👍
A word on the B bolt. One thing I think really helped was instead of just loosening pas reservoir I took a step further and took out the rubber hose from reservoir to pas pump. I also removed upper radiator hose instead of just easing it out of the way. Ok I had to put those things back and refill power steering but it made the job a lot easier........ only imo of course 👍👍👍
