Well after much thinking and several beers! I decided it was best to keep my Double Din unit. I was going to loose too much money on it replacing with single DIN.
So I decided
make that unit fit, and work!
First problem was the cage as too big, almost half a cm!! Grrrr damn Vauxhalls. So I got some Tin cutters and cut the top off the cage, sorry there are not pictures of this, but in the heat and my frustation i thought it was not wise to have an expensive object near me!
So if you imaine a standard HU cage, i cut the top off so it only had 3 sides. After 2 cut fingers, some TCP and a plaster later it was cut down to size.
And it was still a !"&^$%! b!tch to fit in, in the end i used small blocks of wood about an 1inch sqaure and a mallet to get the damn thing in!! But i was worth it.
The headunit now slides in and clicks and holds were it should, here are some pictures of my progress so far:
After messing around with the settings, i got rid of the crappy animations that went on, horrible horrible animations. Looks better just displaying the track name
I have an Aux lead (RCA to headphone) jacking going to the glovebox
The Sub, this Vibe Active unit is amazing!! So powefull! with the boot closed and Ski hatch shut, it still feels like someone is punching the back of my seat!
Please excuse the mess in the boot!
I have on order a facia adaptor, thats next on my list to modify so it fills the gap between the HU and the side buttons.
