Pages: 1 2 3 [All]   Go Down
Author Topic: Best way to join wires - car electronics  (Read 5924 times)
Viral_Jim
  • Telford
    • Too many, mostly broken
« on: 10 June 2017, 18:14:56 »
Bit of an amateurish question - so bear with me.
I have a few jobs on the Swede that require me to join wires to the harness or add additional circuits in off the fuse board.
For the joints/connections I'm tempted to solder the wires and heat shrink the joints. This "feels" a better way than those crimp connections (which I also have plenty of). But I'm conscious that soldering creates a stiff section in the wire that could stress and break over time  :-\.
What are your thoughts? Is there an alternative method I haven't considered?
Re: Best way to join wires - car electronics
« Reply #1 on: 10 June 2017, 18:44:53 »
Solder and shrink wrap is the best imo. Can't come apart and are well insulated.
« Reply #2 on: 10 June 2017, 18:46:08 »
But, then again, I haven't done any of this stuff for yonks, and no doubt they'll have invented something better  :-\
Lincs Robert
« Reply #3 on: 10 June 2017, 18:52:30 »
+1
I HATE Scotchlok connectors as they actually damage the cable.
This is what the industry do when they make the looms with built in splices - but they take it one stage further by having resin inside the heat shrink to provide mechanical support to the soldered joint. Also, beware when repairing a broken wire as the repair will consume cable length! The way round that is to make a double splice to restore the original length - if you see my logic?
« Reply #4 on: 10 June 2017, 19:03:27 »
+1
so how do you do the solder? Lie each tinned wire side by side & apply heat or twist together & solder it all ......  :-\
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
« Reply #5 on: 10 June 2017, 19:06:55 »
Easier to watch then explain, sorry it's. American
https://m.youtube.com/watch?v=Zu3TYBs65FM
Hoof'land storeman.
Viral_Jim
  • Telford
« Reply #6 on: 10 June 2017, 20:47:36 »
Cheers :). Despite being a yank he seems to know his stuff!
First attempt:
I suspect my soldering iron wasn't quite man to the task - 30 watts of pure power when it was new (13yrs ago). But you know what they say about bad workmen! ;D
omega2018
    • 2.6 manual elite
« Reply #7 on: 10 June 2017, 21:20:02 »
yes i connect wires like that but a 12v electrician i know always just crimps wires with a decent crimper.  i think just because it is much quicker.  when i've tried crimping i can often pull the joint apart, soldering is much stronger and longer lasting
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #8 on: 11 June 2017, 12:15:16 »
I used to love soldering til I found crimp bullet connectors. Crimp. Crimp. Melt each end to set the built in glue. Done. 👍
RIP Paul Lovejoy
Viral_Jim
  • Telford
« Reply #9 on: 11 June 2017, 17:59:04 »
Interesting web by! Never come across Ines with glue in (unless I've bought them without knowing). The crimp ones I have are the basic ones- spade connector with a metal tube on plus a coloured plastic sleeve over.
Do you happen to have a link?
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #10 on: 11 June 2017, 18:01:58 »
If youve ever owned a series land rover you wouldnt use a bullet connector again !. The looms were made of seperate sections all around the vehicle and then plugged together. All fine and dandy when new but they dont like vibration or moisture and cause all sorts of issues eventually. Twist ,fluxed electrical solder and shrink sleeve best way to go in my opinion .
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #11 on: 11 June 2017, 18:04:11 »
now try that with a bundle of wires, or where you have to pull them through a hole. A well-done(something many people struggle with) soldered joint is still useful.
Viral_Jim
  • Telford
« Reply #12 on: 11 June 2017, 18:10:33 »
My problem last night was I couldn't get enough heat in the tier to melt the solder onto them. I harts melt it onto the point where the iron and wire touched and then try to flow it on from there. Not sure if the iron lacked oomph or my technique was poor (or both).
cam.in.head
  • West yorkshire
« Reply #13 on: 11 June 2017, 18:17:01 »
Providing you are not soldering in the wind /draught and you are not accidently using a high melting point solder then the solder should melt easily on the tip of the iron and flow into the joint easily as well. If it doesnt then you must have a lower powered iron than will heat the joint.make sure the tip is secure in the end /especially critical with the wire loop type gun irons. And that the tip is clean.
Webby the Bear
  • Northampton
RIP Paul Lovejoy
Viral_Jim
  • Telford
« Reply #15 on: 11 June 2017, 22:49:58 »
Cheers mate  :y
Bought those to go into stores, they have the look of something that'll come in useful!
Webby the Bear
  • Northampton
« Reply #16 on: 12 June 2017, 14:06:52 »
Oh god yeah mate. Easier for me than soldering and as said when u melt the heat shrink there's a glue in there to
RIP Paul Lovejoy
« Reply #17 on: 12 June 2017, 17:23:08 »
Crimped connectors, even with adhesives/resins to try to give them some element of mechanical strength, will always be unreliable. Always.  I doubt anyone would dispute then, including the manufacturers.  Also, you need a crimp type very specific for the type of cable you are doing, and most bullet crimps or scotlok type are wholly unsuitable for multistrand cable, and virtually all loom cables in a car are going to be multistrand for a reason...
Crimps are fast though. Hence the bodgers love them. They rarely last, and cause no end of reliability niggles down the line...  ...the type that are a PITA to trace.
I prefer solder and heat shrink.  If I'm worried about mechanical strength, you can get heatshrink with a heat activated adhesive on, but I tend to use normal adhesive, and heatshrink when its just going off ::)
Yesterday, I was fault finding an electrical issue on a large ride-on mower. Where was the fault? Yup, a (manufacturer done) crimped connector.
Webby the Bear
  • Northampton
« Reply #18 on: 12 June 2017, 19:32:44 »
I'll add at this point....
"Technicians" at Audi are not allowed to solder wire repairs. They can get a disciplinary should they solder anything.
I'll leave you lot to mull that over  :y
RIP Paul Lovejoy
« Reply #19 on: 12 June 2017, 19:41:08 »
And that's a surprise why?
BMW Fitters weren't allowed to remove the sump plug during a service :-X ::)
Webby the Bear
  • Northampton
« Reply #20 on: 12 June 2017, 19:47:58 »
It's not a surprise when you hear stories of what can happen when things are soldered  :)
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #21 on: 12 June 2017, 19:50:37 »
Ps, before this turns in to an OOF witch hunt  ;D ;D ;D I don't care what anyone chooses to do. It's your car so you do what you like. I personally choose the shrink/crimp things cos soldering is tricky for me. That's not to say I can't do it. But these things are so much easier  :y
RIP Paul Lovejoy
« Reply #22 on: 12 June 2017, 19:56:24 »
Oh no no no. You don't wriggle out of it that easy, you bastard!  ;D
Webby the Bear
  • Northampton
« Reply #23 on: 12 June 2017, 19:58:36 »
RIP Paul Lovejoy
« Reply #24 on: 12 June 2017, 20:35:41 »
If taped up rather than properly sealed, you can get corrosion at the end of the solder, if in a harsh environment. Or poor quality solder used.
Otherwise, generally not an issue...  ...certainly better than scotchloks or those silly bullet/spade type crimps :y
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
    • 3.2 Elite. Boxster. C1.
« Reply #25 on: 12 June 2017, 21:02:06 »
I usually take the car to work and get a professional to do it. I struggle to solder with two hands, Christ knows how Webby would even attempt it.  ::)
Women are like an AR35. lovely things, but nobody really understands how they work.
Andy H
  • Auckland
    • Mazda MPV
« Reply #26 on: 12 June 2017, 21:14:22 »
From my (limited) experience of VAG cabling I would suggest that the quality of the wire used is such poor quality that they would be wasting their time anyway........
  • Online Online
  • Solihull
    • 530D M Sport, Elite 3.2
« Reply #27 on: 12 June 2017, 21:34:39 »
Agreed, I'm bored of repairing the fragile looms on Mrs VXL's Alhambra now.
Webby the Bear
  • Northampton
« Reply #28 on: 12 June 2017, 22:03:21 »
I honestly can't remember the reason why it's "illegal" in vag world but I'll find out tomorrow 👍
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #29 on: 12 June 2017, 22:06:52 »
Scalding hot solder gun held under my "small arm" 😂 Twisted wires sat carefully on top of iron. When all wires hot enough solder flows through. But it's a right ball ache if they are thick wires as takes ages to heat. These heat shrink connectors are done in a couple of minutes even by me 😂
RIP Paul Lovejoy
« Reply #30 on: 12 June 2017, 23:46:08 »
If you look at practically any connector on any car loom, 99 times out of 100 it'll be crimped at the factory.
When the wire, connector and tool are 100% compatible, it is a very reliable method of connection in an environment with movement and vibration like a car, because it doesn't concentrate stress on the cable like a soldered joint does.
However, DIY crimping tools are not great unless you spend quite a bit, and you need exactly the right size connector for the wire, and the right tool for the connector. I must admit, if I need to connect something to a car loom I generally use a solder joint, but I make sure it's supported by heat shrink sleeving and, preferably, cable tied to something solid locally to stop the wire flexing.
Don't use a scotchlok, whatever you do. ::)
Viral_Jim
  • Telford
« Reply #31 on: 13 June 2017, 00:10:18 »
No fear! When I first got my kit car (more than a decade ago), I spent an unpleasant 3 weeks one summer removing about 100 scotch locks and trying to decipher the loom. The sadistic b@stard who built the damn thing only used light blue wires - and I mean for EVERYTHING!  >:(
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
« Reply #32 on: 13 June 2017, 00:36:07 »
You must be very determined mate. I would like to try to replicate this, just to see how difficult it is, but I know I would burn holes in myself from head to toe.  ::) ;D
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #33 on: 13 June 2017, 08:04:11 »
Rewiring MrsGKs Polo,half the wires for the banging sound system were Scotchlocked, half of them twisted together and taped... Several of them burnt!
« Reply #34 on: 13 June 2017, 09:26:59 »
Yes, indeed. I take my hat off to you, Webby. :y Since "electron herding" is my hobby, I do quite a lot of soldering and normally two hands aren't quite enough.
I find a "helping hands" very useful in this scenario.
http://www.clasohlson.com/uk/Helping-Hand-Work-Aid/30-7666?gclid=CJrjoeuyutQCFUQz0wod-YEKnA
You can use it to hold the wire and connector in place, then you can apply the solder and iron.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #35 on: 13 June 2017, 10:52:03 »
An excellent tool, i have had mine for years, and cannot imagine how I managed to solder before I had it.
Viral_Jim
  • Telford
« Reply #36 on: 13 June 2017, 10:57:53 »
I went for 2 stacks of magazines, with one wire sandwiched in the middle of each stack. That said, if I had to do more than half a dozen wires every decade or so, I might have to invest in an alternative solution!  ;D
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #37 on: 13 June 2017, 12:42:16 »
Bloody hell! I've got one of those...wondered what it was  for ::)
I like red cars
« Reply #38 on: 13 June 2017, 12:49:33 »
;D ;D ;D ;D ;D ;D
TD
  • Swindon
    • Nowt!
« Reply #39 on: 13 June 2017, 18:01:19 »
In my yoof I used to work for a company that manu'd 16/18in 10/12 copper layer circuit boards.
All the components were surface mounted.....
When they didn't work I had to fault find them and change the duff component.....
This involved peering through a dual microscope just to see what you were doing and the soldering iron tip was heated with RF energy as it so fine...IIRC the soldering irons cost about £500 each and the tips for the irons about £50 each.....which would need replacing every week as the irons were left on 8/10hrs a day........
Probably what buggared up my eyesight...... :-\
Migv6 le Frog Fan
  • Webs End.
  • Nicole's Papa
« Reply #40 on: 13 June 2017, 19:05:07 »
;D ;D ;D ;D ;D ;D
I see them all over the place on work and had no idea what they were for either.  ::)
« Reply #41 on: 13 June 2017, 19:13:17 »
Handy bits of kit, not that I've replaced mine following the garage incident.  I should really.  And its my burfday soon.
Pages: 1 2 3 [All]   Go Up
Page created in 0.05 seconds with 21 queries.
