Author Topic: Management light on  (Read 924 times)
  • Millennium Man
    • The missus mad
Re: Management light on
« Reply #30 on: 20 April 2019, 10:26:11 »
Either the spanner light or engine light will leave a code in the engine ECU on a 3.2.  The pedal trick *WILL* work.
Ensure throttle is absolutely fully down, and brake is down enough to activate both brake pedal switches.
And OBDII reader can read 3.2 engine (only). I personally use an Autel one, but others available.  Generally not a fan of the laptop/phone based ones, mostly because they are awkward/shite/limited.
I don't tolerate bickering, and I'm always grumpy.
And Lizzie Zoom says I'm a heartless bastid...and she's absolutely correct!
Bigron
  • Online Online
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« Reply #32 on: 20 April 2019, 11:35:10 »
That should suffice  ;)
Bigron
  • Online Online
  • Witham, Essex
« Reply #33 on: 20 April 2019, 11:36:38 »
Good. Thanks DG. :y
Ron.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #34 on: 20 April 2019, 14:27:25 »
A cheap BT Dongle off the Bay, couple of quid, and the free version of "ScanMyOpel" App off the PlayStore will be good enough to sort your codes out.
Bigron
  • Online Online
  • Witham, Essex
« Reply #35 on: 20 April 2019, 17:02:56 »
Er, my phone is dead basic, not smart, and only goes "Ring, bloody ring" - nuffink else, Zirk! :(
Ron.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #36 on: 20 April 2019, 17:27:19 »
I know TB will hate it, but what do we think of this one?
https://www.ebay.co.uk/itm/MS309-OBD2-Car-Diagnostic-Scanner-OBDII-Engine-Check-Fault-Code-Reader-Date-Test/273150971347?hash=item3f99110dd3:g:p6wAAOSwantbmit3
Ron.
I wonder how long it takes to come from Nifeng Liu B1123-1126, Yousong Technology Building 11F,Donghuan First Road, 518000 Shenzhen? :-\ :-\ :-\
Shackeng
  • Ramsbury
« Reply #37 on: 20 April 2019, 17:28:36 »
As you know Chris, I am a techno numpty, so you are speaking in tongues. ;D ;D ;D
Shackeng
  • Ramsbury
« Reply #38 on: 20 April 2019, 17:32:49 »
Does the EML light go off after so many starts if fault no longer exists? Or am I thinking of other codes. :-\ :-\ :-\
Bigron
  • Online Online
  • Witham, Essex
« Reply #39 on: 20 April 2019, 17:34:59 »
Well, it was promised for delivery on Thursday next, the 25th. April - I hope they meant this year! ::)
Ron.
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #40 on: 20 April 2019, 19:06:58 »
Ron.
about 20minutes. Unless you live in Brackley. Then they'll send you a rubber chicken in time for the August bank holiday festivities......
Shackeng
  • Ramsbury
« Reply #41 on: 21 April 2019, 09:42:30 »
Anybody?
dave the builder
  • Online Online
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #42 on: 21 April 2019, 10:07:53 »
Anybody?
the EML goes out on it's own if the fault is "not present" but stores the code for about 20 ignition cycles on most vauxhalls in my experience .
so if your light remains on when driving, i'd say you have a fault
no one local with a code reader ?
Shackeng
  • Ramsbury
« Reply #43 on: 21 April 2019, 10:18:51 »
Thanks Dave, Entwood has kindly offered, and lives nearby, but I do need to get one of my own.
As I only use the Omega on days such as today, it will take time for 20 starts.  :y :y :y
  • Millennium Man
    • The missus mad
« Reply #44 on: 21 April 2019, 13:05:15 »
Ron.
Its a chinky knock off. Will likely be OK, though might not last the warranty period.  Looks like that cant do live data.
I'd spend a little more on a genuine one from a real UK shop personally.
Pages: 1 2 [3] 4  All   Go Up
Page created in 0.114 seconds with 22 queries.
