Author Topic: Wanted - Estate Roof Aerial & Base  (Read 4182 times)
Clouseau
  • Telford
  • Keeping the dream alive...
« on: 01 March 2012, 16:13:14 »
*** Mods please move to 'Wanted' Section*** :y
I'm after an estate roof aerial base and genuine VX whip aerial to match ... must be amplified and have the multiplug intact. The rubber seals on the base can rot a bit, so a decent one would be preferable.
Anyone help?
SJKOO01
Re: Wanted - Estate Roof Aerial & Base
« Reply #1 on: 01 March 2012, 16:54:00 »
I believe RobG and Twiglet were breaking up an Estate, maybe worth a PM to them?
twiglet
  • Norwich, Norfolk
« Reply #2 on: 01 March 2012, 18:02:46 »
Sorry mate, I've had 2 of these now, but have sold both.  They don't come up very often I'm afraid, so I suspect a degree of patience will be required.  :y
Olympia5776
  • Ireland
« Reply #3 on: 01 March 2012, 18:40:40 »
If you have a spoiler on the tailgate you'll have to make sure you get the steeper angled base .
The shallow angled one will make contact with the spoiler when the tailgate is opened scraping the paint in no time. :y
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« Reply #4 on: 01 March 2012, 20:25:53 »
Are there two different bases then good job I read that then as I want to fit a spoiler when I find one  :y
twiglet
  • Norwich, Norfolk
« Reply #5 on: 01 March 2012, 20:41:53 »
Just to clear this up, in order to change the angle of the ariel so to clear the spoiler, you would use an adapter (such as the prodrive ball). This screws into the base, and the ariel in turn screws into this.  The base itself remains unchanged.
However, if you are sourcing a base for your own car, you need to check the connections above the load area light.  There are 2 different tyres. Earlier cars (upto approx. 2001) have individual coax type connectors, whereas latter cars have 1 blue plastic multiplug, which contains all connections.
HTH  :y
Clouseau
  • Telford
« Reply #6 on: 01 March 2012, 20:43:02 »
Having experimented with a 'shark fin' type aerial (and bodged the plugs on the original one in the process) I'm going to ditch this and go back to the original spec aerial, but move it about 10 cm further forward to ensure that it doesn't foul the spoiler when the tailgate is open. ;)
Clouseau
  • Telford
« Reply #7 on: 01 March 2012, 20:43:50 »
Just to clarify then this is for a 2003 car with the later multi-plug :)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #8 on: 02 March 2012, 06:46:52 »
Anyone help?
Do you have sat nav on your estate? If not i may have one here for you. ??? If you do it took me 6 mths to find one
Clouseau
  • Telford
« Reply #9 on: 02 March 2012, 08:06:58 »
Hi - thanks for your reply
No, no sat nav in my CDX, although the multi plug has two identical aerial sockets - I presumed the other one was for the mobile phone aerial?
GmasterT
  • Cambridge
  • does that drifting thing...
« Reply #10 on: 02 March 2012, 12:26:52 »
Do they all have a mobile phone ariel jack then or just the ones that came with the phones (CCR700) ?
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #11 on: 02 March 2012, 17:36:16 »
Now going to look if i have it, give me an hour
