Author Topic: Help! what have I done or not done???  (Read 1795 times)
Crazycarzowner
« on: 23 March 2012, 22:26:51 »
 Changed the camcover gaskets today, it went well really. put everything back together, test drove ok. Then I got the spanner warning. Hooked it up to my test thingy and got this P0330 - (2) Knock sensor 2 circiut Low input (bank 2) present.
Have I missed pluggin someat back in or have I disturbed someat I shouldn't have?
TIA
J
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: Help! what have I done or not done???
« Reply #1 on: 23 March 2012, 22:36:59 »
check to see whether anything unplugged drivers side plenum, also check for trapped wires or loom damage  :y
« Reply #2 on: 23 March 2012, 23:10:27 »
TIA
J
You`ve trapped and possibly damaged the knock sensor cable (screened co-ax) on passenger side, or dislodged the connector.
Courtesy of MDTM
The connector for the knock sensor is indicated by No 2 and the wire clips and runs as shown by No 1
« Last Edit: 23 March 2012, 23:18:17 by RobG »
« Reply #3 on: 24 March 2012, 10:07:09 »
Check passenger side knock sensor is plugged in, and that you haven't caught the wire...
Crazycarzowner
« Reply #4 on: 24 March 2012, 20:49:30 »
Whoops!!!  :-[ :-[ :-[ must have not plugged it home firmly enough. Alls well again now, thanks guys  :y
« Reply #5 on: 24 March 2012, 20:51:59 »
A nice cheap/easy fix.  :y :y
I'm surprised that a bloke as big as you didn't manage to push the plugs together first time!  ::) ::) ::) ;D ;D :y
Crazycarzowner
« Reply #6 on: 24 March 2012, 21:19:49 »
 :P :P :P :P :P :P
I'm a gentle giant really.  ;D ;D
