Author Topic: Cam cover gaskets. The alternatives  (Read 5041 times)
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« on: 05 April 2012, 13:59:30 »
Right. I've been some research on the quality of cam cover gaskets. General opinion  is to use genuine but what is genuine? You can bet your life GM do not make their own gaskets. From past experience I know the gaskets in the straight 6 for the head gasket are made by a outside company. So I did some digging around and found out some information on company called Elring. Now Elring make all sorts of gaskets for many of manufacturers as well as supplying to the trade who in turn sell them to the customer. Elring state clearly on their web site they supply to the makers. So I did some hunting and found a pair of gaskets and O rings. I've ordered them and they turned up today. On Elring's more than helpful website I was able to cross reference the codes and sure enough they are one and the same. Even on the packets they use the GM part number and Kat code. I don't know what the Kat code refers to however having them appear on both websites sounds promising. The quality looks excellent the moulding is spot on. Elring are well known in the VW air cooled scene for being of good quality. So I'm going to fit them and see what happens. As long as the breathers are kept clean I see these lasting another 70 k miles. I will not be using GM sealant (another item you can bet your life they've never made them self) Instead I will use silicone sealant engine RTV oil resistant. I've used this stuff for many years and my friends company who refurbish manual gearboxes use exactly the same without issue. Another bonus with this gaskets is they cost me 18.35 posted to my door. That's for two gaskets and 16 O rings. Part numbers for those who are interested are:-
GM 90511451
KAT 6 07 642
EAN 4041248190821
ELRING 372.320
These are just the numbers for the gaskets not the O rings. Hopefully this will lead to a cost effective alternative to OE gaskets.
Re: Cam cover gaskets. The alternatives
« Reply #1 on: 05 April 2012, 14:17:10 »
I can't for the life of me remember the manufacturers name on the Vauxhall supplied gaskets but i'm sure its not Elring
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #2 on: 05 April 2012, 14:22:59 »
Sounds good mate! Good research
RIP Paul Lovejoy
doz
  • Southampton
« Reply #3 on: 05 April 2012, 14:32:41 »
Full name is Elringklinger AG Which sounds a bit rude if you say it quickly  :-[
Elite_L0ver
  • Eastleigh, Hampshire
  • On too Omega #2
    • 99 2.5 V6, 03 2.2 CD FL
« Reply #4 on: 05 April 2012, 14:36:27 »
What's price difference as mine need it asap inbox me :y
Likes My Music LOUD!!!!
Elm327 code reader And OP COM available Locally PM Me
doz
  • Southampton
« Reply #5 on: 05 April 2012, 14:37:57 »
I think GM charge around 25 per side
« Reply #6 on: 05 April 2012, 14:38:28 »
The genuine ones have the makers name of Grainer or something similiar on them
« Reply #7 on: 05 April 2012, 14:46:10 »
As Pete says. Took this a couple of weeks ago with the idea of similar research.
doz
  • Southampton
« Reply #8 on: 05 April 2012, 14:58:45 »
Good information. From what I've found out Gm use several different suppliers for the same part. Still if they aren't genuine I'll still give them a go and see how they perform.
Dr_X
« Reply #9 on: 05 April 2012, 15:03:57 »
« Last Edit: 05 April 2012, 15:06:23 by Dr X »
« Reply #10 on: 05 April 2012, 15:11:50 »
I've only ever seen the Greiner ones and i've done a lot of cam cover gaskets in my time ;)
bigboykarl
  • barnsley/london.
« Reply #11 on: 05 April 2012, 15:12:35 »
klinger make the metal head gaskets for rover turbo lump and the kv6 and have a good name in that circle
« Reply #12 on: 05 April 2012, 15:16:12 »
Send then back and save yourself some time and money. Some wise words from the Master contained in the link below :y
http://www.omegaowners.com/forum/index.php?topic=76791.msg1030981#msg1030981
doz
  • Southampton
« Reply #13 on: 05 April 2012, 15:19:06 »
Strange that part number in the picture doesn't reference to the opel site for the gasket used in the 3lt
