Pages: [1] 2 3 4 5 6 7 8 9   Go Down
Author Topic: Servo tronic relay location 3.2  (Read 31347 times)
« on: 04 May 2012, 01:50:06 »
03 year. Where is it? Behind glove box?
...or I've also seen mention if drivers side kick panel.  :-\
Re: Servo tronic relay location 3.2
« Reply #1 on: 04 May 2012, 01:54:21 »
I believe it's as Robs guide by the way, but thought I'd check model variants...?  :)
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #2 on: 04 May 2012, 06:17:22 »
Don't know if this varies by which side the steering wheel is but in my late 2,6 (which I expect to be exactly as yours) it is behind the fuse box  :y Must remove the panel covering the steering rack/shaft to reach it.
« Reply #3 on: 04 May 2012, 08:43:06 »
Could be either Chris, but late one`s tend to be up under cabin fusebox
« Reply #4 on: 04 May 2012, 09:26:51 »
Yep. What he said. ^
« Reply #5 on: 04 May 2012, 10:02:33 »
Cheers chaps. Off for a butchers. :)
2woody
  • Northumberland
« Reply #6 on: 04 May 2012, 16:18:22 »
mine's up under the fusebox - in the "down the footwell on your head" position. It's red and says servotronic on it.
« Reply #7 on: 23 July 2012, 15:43:09 »
Drove TB's briefly yesterday. Much easier to steer than mine.
So it's not servotronic relay.
What's next easiest to check..?
Baring in mind symptoms are complete opposite of a tired pas pump. In that the assistance is greater at low revs, and much heavier at high revs. Is sumat wired up backwards...? :-\
« Last Edit: 23 July 2012, 15:45:24 by chrisgixer »
« Reply #8 on: 23 July 2012, 15:44:56 »
Just rang the dealer, and there is mention of warranty work on a steering linkage. But there are no further details available.
« Reply #9 on: 23 July 2012, 18:25:12 »
Well, its pump or box.  Pump easier.
« Reply #10 on: 23 July 2012, 18:26:22 »
Just a thought Chris, have you changed the idler on that one yet :-\ iirc there are different lengths...not sure what effect that would have though.
« Reply #11 on: 23 July 2012, 20:49:32 »
What's the electrical connection to box? :-\
« Reply #12 on: 23 July 2012, 20:51:23 »
I have never done an idler, believe it or not. But the Dealer "could" have changed it I suppose.
Only other thing in my mind is the known to be pitted top mount bearings. :-\
« Reply #13 on: 23 July 2012, 20:54:46 »
That wouldn't help because you'd be trying to turn against the springs :-\ thinking about it, migght it be worth changing them :-\
« Reply #14 on: 23 July 2012, 21:36:07 »
They do turn, but they will do when jacked. Not sure how to check while driving at 40mph. :(
As you say though, might be worth changing them. :-\ I even tried driving up the road with the top mount nuts loose, knocked like hell but still stiff steering. :( loose nuts wouldn't affect the load of the car on the bearings though I suppose.
But my gut feeling is an on going issue.
Pages: [1] 2 3 4 5 6 7 8 9   Go Up
