Author Topic: Radiator Drain Maintenance.  (Read 7615 times)
Mikes1670
  • Hull
« on: 07 May 2012, 18:51:40 »
Just wondered while I have got my coolant drained from the system is there anything to maintain on the radiator drain - washer/seals etc - is it possible? Also, when tightening the drain thumb screw is finger tight sufficient? :y
Re: Radiator Drain Maintenance.
« Reply #1 on: 07 May 2012, 18:54:56 »
I usually tighten it to finger tight + a nip  :y :y :y
The O rings will be OK as long as they don't show signs of being perished.
Mikes1670
  • Hull
« Reply #2 on: 07 May 2012, 18:56:55 »
I take it you can remove the drain screw then to inspect the o-ring seals?
« Reply #3 on: 07 May 2012, 18:59:18 »
You can. Unscrew it and it'll get  to the end of the thread and feel loose, just a case of pulling it out then.
« Last Edit: 07 May 2012, 19:01:18 by Andy B »
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #4 on: 07 May 2012, 20:27:50 »
<pic>
This is why I love OOF - someone will have a photo, part number or diagram for everything. :y
« Reply #5 on: 07 May 2012, 20:59:22 »
That'll be Rob G  :y :y :y :y
« Reply #6 on: 07 May 2012, 21:00:18 »
Someone call ;D ;D ;D :D
GmasterT
  • Cambridge
  • does that drifting thing...
« Reply #7 on: 08 May 2012, 10:14:27 »
Lol, where can you get new ones of them? :D
« Reply #8 on: 08 May 2012, 10:24:31 »
Main dealer, couple of quid for new plug with O rings. Part #93194704
« Reply #9 on: 08 May 2012, 15:28:38 »
I went that route and the new one leaked!
Looking carefully the new one (black in colour and apparently superceding old red one) is slightly different from the red in terms of o-ring spacing - solution fit new o-rings from black one to red one - result no leaks :y
Mikes1670
  • Hull
« Reply #10 on: 08 May 2012, 18:46:04 »
Cheers for the info. I've just ordered a new one today (only £1-83 + VAT from the stealers) - at point of ordering he said the part had been superseded, hence the difference. I will swap the seals over. :y
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
« Reply #11 on: 08 May 2012, 19:14:57 »
Second that! Did mine a little while ago, leaked more with the new plug in, swapped the new O-rings to the old plug and job done!
It was just £2.15 iirc but that's bl**dy expensive O-rings if you ask me.
I would've just fitted normal one in but the VX rings have graphite or something in them....
Mikes1670
  • Hull
« Reply #12 on: 10 May 2012, 19:04:23 »
Looking at the photo of the drain cock in this thread is one of the seals out of it position? i.e. not in the groove - funny thing was when I removed mine it was exactly like the one in the photo but would like to know what the correct seal position should be :y
Abiton
« Reply #13 on: 10 May 2012, 20:09:29 »
You'll be wanting my picture...as it should really look, and with technical terminology...
 :y ;D
« Reply #14 on: 10 May 2012, 20:28:20 »
and when compared with Abiton's picture, it does appear that my O rings isn't fitted correctly. Never noticed that before. There's a new one in my car, & I've never touched the O rings in that, so if they're wrong it's GM's fault.  ;D ;D
