Pages: 1 2 [3]  All   Go Down
Author Topic: solenoids in ar25 box  (Read 9210 times)
amba
  • Medway towns
    • German V6
Re: solenoids in ar25 box
« Reply #30 on: 21 May 2012, 17:21:38 »
Just checked the 2 I have and they are reading:
17.8 ohms for 1  :y   other is 21.9 ohms. :'(...so on that basis I have atleast 1 good one working within reading tolerances.
Now as they are both identical/interchangeable I can remove the 2/3 change solenoid from my gearbox and fit a good working one in its place ;D
Be interesting to see what the readings are from the 2 in the box.
When its described as a "sticking solenoid" would that mean grit/dirt or something causing it to not work correctly or would it be down to a highre or lower ohm reading .
amba
  • Medway towns
    • German V6
« Reply #31 on: 22 May 2012, 09:46:25 »
Anybody able to confirm what likely to be causing 1 solenoid to "stick" ?
Can they get small particles of dirt inside them then as look pretty sealed to me .
« Reply #32 on: 22 May 2012, 09:57:56 »
Depends what the "normal" failure mode is, TBH.
I can imagine that if the fluid has been allowed to get dirty there might be the possibility of them getting jammed with crud. Then again, the fluid supply to them is well filtered.
On the other hand, maybe it's an electrical issue. Without analysing a few failures it's impossible to tell.
Maybe the difference in resistance is significant, maybe it's just the normal spread you'd expect? Maybe the different part numbers have slightly different resistances?
Given that you've got a couple of spares, I'd be inclined to swap that solenoid anyway and see if it makes a difference. Any difference at all is an indication that we're on the right track.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #33 on: 22 May 2012, 10:21:46 »
andy try just replacing the 2-3 one with the one good one you have i think...cos you said the other onea bit naf :y
Tangerine
    • 6-2000 2.5TD Auto CDX
« Reply #34 on: 14 September 2014, 16:30:40 »
I have just come across this thread and it seems to cover exactly the problem I am experiencing.
Is it difficult to change the 2-3 solenoid and is it the same item in a V6 facelift box as in a TD facelift box?
Pages: 1 2 [3]  All   Go Up
