Author Topic: changing automtatic transmission oil.  (Read 4403 times)
speedie
  • braintree
    • 3.0 mv6 omega estate
« on: 05 July 2012, 18:58:02 »
hi people, i have no idea when my mv6 transmission oil was changed and from 1st to 2nd it thumps abit!! but not when warmed up. should i be concerned and is it cheap and cheerfull to services the gearbox????
Re: changing automtatic transmission oil.
« Reply #1 on: 05 July 2012, 19:05:42 »
If the fluid hasn't got a history of being changed i would say it's always wise to do so.
It's worth carefully checking the condition of the old fluid. If it smell burnt or has any debris in it, it's likely the box is in poor condition.
Watch out for plastic bits in the front sump, as this indicates a failed thrust washer which will kill it in short order if not replaced.
amba
  • Medway towns
    • German V6
« Reply #2 on: 05 July 2012, 20:01:25 »
Servicing the autobox works at about ..
£70=00 for 2 x 5ltrs Dex III,which can be purchased from Opie oils who have an advert on the "For Sale Section ".
You will require both the front/rear sump gaskets along with the filter screen which is easier replacing although some would wash it out in paraffin.These work out about £40=00 for the set which can be bought via ABS .
Means of getting the new oil into the sump is best with a 5ltr garden type sprayer which could be picked up for around £10-£15 so expect £120=00 to do the job properly using decent parts and oil.
If you intend doing it yourself so much easier on a garage ramp if you could beg/borrow/steal the use of 1 ,failing that its ramps on the driveway.Expect to get messy so have plenty of old carpet/rags/paper to mop up the mess and suggest you wear some old clothes as you will get dirt...be warned. ;D
the alarming man
  • medway kent
    • disco V8
« Reply #3 on: 05 July 2012, 20:12:11 »
andrew you paid £70 for 10 litres of dex 3...i paid £38 up at lessness autos for the same oil opie stock/sell
amba
  • Medway towns
    • German V6
« Reply #4 on: 05 July 2012, 20:35:15 »
Mark.
Bought Titan 4000 in 5ltr bottles from Opie,s website as per forum...worked out about £35=00 per 5ltr.
Are you sure you didn,t buy Carlube stuff ??
ted_one
« Reply #5 on: 05 July 2012, 20:44:14 »
Is there a problem with Carlube Dextron or their other products?
amba
  • Medway towns
    • German V6
« Reply #6 on: 05 July 2012, 20:45:16 »
Fuchs TITAN ATF 4000 Multifunctional Automatic Transmission Fluid -
"Good quality universal ATF for all Dexron III applications."
1197
5 Litres £27.78 (£23.15 ex)
Just lifted from their website...looks like it a bit cheaper than when I bought it a few weeks ago.They had a deal on 2 at about £65=00 and 1 at £35 so still considerably more than you paid at £39 for 2 x 5ltr
amba
  • Medway towns
    • German V6
« Reply #7 on: 05 July 2012, 20:49:02 »
I had understood that Carlube was a lower quality product and as it was in effecty going into a gearbox that wouldnt be opened up again for some considerable time it was wiser to opt for the better quality.
Sure engine oil is less of an issue as its a consumable which is replaced every 4/5k anyway so basic cooling/lubricating properties are acceptable.
Above comments are just my own opinion though  ;)
the alarming man
  • medway kent
    • disco V8
« Reply #8 on: 05 July 2012, 20:56:50 »
deffo titan BUT i am wondering if they messed up on the price...carlube is what daz uses though...i think car lube is a lot better than what it was.. :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #9 on: 05 July 2012, 21:43:59 »
  i use shell donax in my box makes the changes nice and smooth and the gaskets and filters from abs. :y
Hoof'land storeman.
speedie
  • braintree
« Reply #10 on: 05 July 2012, 23:45:24 »
Thanks for all the info guys, i'm tempted to get all the oils and filters and pay someone to do the job ;D any idea how much 1 would charge  :-\££££££
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #11 on: 06 July 2012, 08:09:53 »
Comma gearbox oil is what I use  :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #12 on: 06 July 2012, 08:16:03 »
the alarming man
  • medway kent
    • disco V8
« Reply #13 on: 06 July 2012, 09:15:18 »
well i knew it began with a c...i was nearly there.... :y
« Reply #14 on: 06 July 2012, 09:54:56 »
Thats the stuff Halfords sell for around £20 (before trade discounts), which I have used.  No idea why, or even if its just a placebo effect, but I feel Titan 4000 is noticibly smoother in use.
Given the extra cost, and how rarely it has to be done, I tend to use Titan 4000.  Although, in an emergency, Halfords and their Comma is more convenient, hence its whats currently in the MV6 following the Newent fiasco last year ;D
