Author Topic: Sorry to start new thread but can you tell me min. rear pad/disc min thickness?  (Read 2178 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
need to measure these at the weekend and i dont trust the haynes.
ps, thought freecall had answered this on a previous thread but he was talking about his wheel alignment measurements  ;D
RIP Paul Lovejoy
Webby the Bear
  • Northampton
sh*t, just noticed i've excreted over 4000 posts  :) :) :) :) :) i use the word excrete cos most of my posts can be likened to taking a......  ;D
RIP Paul Lovejoy
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Imo, any pad with less then 5mm on it needs replacing
Webby the Bear
  • Northampton
ok, thanks TG. Two q's to that then...... does 5mm inc. the backing plate of the pad? and do you know what min disc thisckness should be at ze rear? :)
RIP Paul Lovejoy
Martian
Autodata shows the following:
Minimum disc thickness - 10mm
Disc thickness variation - 0.010mm
Disc runout - 0.10mm
Minimum pad thickness - 6mm
Pad thickness measurement includes lining & backing plate.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
The 5mm is just the friction surface  ;)
After that, they tend to heat up a fair bit under hard use so I always change them a bit early  :)
As for the discs, is they a lip on the edge yet ?
Again, if its just a small lip (1mm ish) I tend to attack it with a angle grinder before I fit new pads or they don't sit properly on the disc when you brake.
The pads will let your ears know when theyve had enough. ;) ;D
Webby the Bear
  • Northampton
Thanks very much guys.
TG, am checking on Sunday  :y
Martian, sorry whats variation and runout?
Cheers.
RIP Paul Lovejoy
STMO123
Cheers.
You'll kill some poor bastid soon ;D ;D
Martian
Variation is the figure that dictates how much the disc thickness can be out at any given point. (eg, if you measured 11mm thick at the 12 o clock position, that thickness cannot increase or decrease by any more than 0.010mm at any other position).
Runout is how true the disc is when it is spun on it's centre axis.
Webby the Bear
  • Northampton
thats a perfect explanation. Thanks mate :-)
RIP Paul Lovejoy
