Author Topic: Can any one help please Vectra V6 engine misfire???  (Read 5347 times)
carswaps
  • West Yorkshire
    • Omega MV6 3.2 Estate
« on: 08 August 2012, 17:56:16 »
Now i know its not an omega but it does share the same engine!
I,ve got a Vectra 2.5 V6 with a misfire problem and after trying almost everything i thought i'd give you guys a try!
After getting upto temperature its got a misfire from 2300rpm! (its perfect when cold)
You can't get it to clear by giving it more throttle.
Its fine at idle and right upto 2300rpm then it kicks in (almost feels like a rev limiter)
Its also fine when you rev it up standing still so its only happening under load.
Here's what i've done and still no change.
New coil pack, new plugs, new HT leads, new CTS, new TPS.
The timings also spot on!
I,ve had the car on <admin edit> and its showing no fault codes however i did do the paper clip test with the ignition on but not running and it came back with code 0335:
P0335 Crankshaft Sensor Incorrect Signal C-06
P0335 Crankshaft Sensor Open Circuit C-06
But i,m not sure if it showed this because the engine wasn't running?
Any help would be great.
Thanks Steve
« Last Edit: 08 August 2012, 19:41:53 by TheBoy »
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Can any one help please Vectra V6 engine misfire???
« Reply #1 on: 08 August 2012, 17:59:17 »
Crank Sensor would be my next choice.
« Reply #2 on: 08 August 2012, 18:14:37 »
Arh vectra memories , nice looking car that  :y Had A 2.5 veccy myself , hope you get it sorted ..
« Reply #3 on: 08 August 2012, 19:42:34 »
0335 is a definate fault that needs investigating...  ...so change the crank sensor.
« Reply #4 on: 08 August 2012, 19:52:09 »
Never been a Vectra fan,but thats lovely. :y
carswaps
  • West Yorkshire
« Reply #5 on: 08 August 2012, 19:59:37 »
Thanks guys
I,ve got a genuine GM crank sensor on the way, I just hope it fixes it!
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #6 on: 08 August 2012, 22:48:35 »
Nice looking car,may be worth running live data and checking what the MAF is up too if the crank sensor doesn't improve it
other rides
  mk3 Volvo v70 2.0 Diesel ,Citroen C2, Pug 306 cabriolet
Manual Elite V6
  • Swansea
  • Mechanic and MOT tester at a Jaguar specialist.
    • 1992 Cavalier GSi
« Reply #7 on: 08 August 2012, 22:58:34 »
Misread post sorry.
« Last Edit: 08 August 2012, 23:00:22 by Manual Elite V6 »
1992 Cavalier GSi
2007 Astra Sri+ CDTi 150
megaelite
    • a car
« Reply #8 on: 10 August 2012, 10:22:45 »
i doubt its the crank sensor, you will get the crank code if the engine is not running, does it cut out while driving and then doesnt start for a while if so then yes its the crank sensor,
carswaps
  • West Yorkshire
« Reply #9 on: 10 August 2012, 21:40:44 »
Nope doesn't cut out when driving....
Very very occasionally it doesn't start with the first key turn.....just spins over then eventually splutters into life.
carswaps
  • West Yorkshire
« Reply #10 on: 11 August 2012, 12:43:21 »
Just a quick update it was the crank sensor, changed it this morning and all is back to normal again.
Thanks for your input guys! :)
