Author Topic: Hazards keep flashing  (Read 1874 times)
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« on: 29 September 2012, 19:55:32 »
Decided to turn over the miggy as she has lay in the drive for about a month. Had to give her a jump as the battery was flat. She started no bother but the problem is that the hazards wont stop flashing. Ant ideas anyone.
Re: Hazards keep flashing
« Reply #1 on: 29 September 2012, 20:00:59 »
Assuming you still have the powersounder connected try hitting the switch on & off a few times
« Last Edit: 29 September 2012, 20:03:04 by RobG »
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #2 on: 29 September 2012, 20:18:47 »
PS disconnected a long time ago.
« Reply #3 on: 29 September 2012, 20:34:25 »
Sounds like the indicators are flashing the alarm (obviously silent due to no PS). If switching hazards on/off a few times doesn`t stop them you can pull the relay that controls the alarm indicators.
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #4 on: 29 September 2012, 21:04:59 »
Cheers Rob, which relay is it. Under dash or in box at battery?
« Reply #5 on: 29 September 2012, 21:11:16 »
Sounds like the alarm has been acticvated but is silent due to missing ps.
Re set it be locking / unlocking with the blipper...? Will need a sufficiently charged battery though. No ...?
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #6 on: 29 September 2012, 21:16:56 »
Cheers Chris
« Reply #7 on: 30 September 2012, 12:44:29 »
If it is the alarm, then the alarm horn is knackered as well...
