Author Topic: omega heating  (Read 4726 times)
maryso
  • kent
  • car dunce....willing to learn!!
    • omega
omega heating
« on: 16 November 2012, 20:35:57 »
heating blowing cold, gggrrr, help please???
Big_Al
Re: omega heating
« Reply #1 on: 16 November 2012, 20:59:12 »
Was it hot & now it,s just cold or has it been cold  only  & no heat  for a while ?
The more info you give the more chance the experts on here have of diagnosing the problem .
What year & which  engine would help to start.  Any coolant leaks at all etc.
With full input from you they will hopefully get to the bottom of it  :y :y :y
maryso
  • kent
    • omega
Re: omega heating
« Reply #2 on: 16 November 2012, 21:07:08 »
omega 2002 gls fan working but just cold air!!! picked it up from ex husband 2 days ago so no idea if it was working, coolant etc all full, no leaks xx
maryso
  • kent
    • omega
Re: omega heating
« Reply #3 on: 16 November 2012, 21:15:45 »
and please dont ask me to call ex, !!!! >:(
symes
  • oxford
    • R reg 940 volvo
Re: omega heating
« Reply #4 on: 16 November 2012, 21:16:32 »
reckon HBV not working -if heater worked now doesnt-or thermostat stuck
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: omega heating
« Reply #5 on: 16 November 2012, 21:20:54 »
Temp gauge working ok? Might point to stat ....
Big_Al
Re: omega heating
« Reply #6 on: 16 November 2012, 21:23:43 »
Do you know which engine you have ?   V6      or 4 cylinder ?
Is engine temp gauge  running at normal  mid position ?
Could be something as simple as a vacuum pipe off .  :-\
Someone more knowledgeable will be along shortly.
There is an Omega meet in Kent tomorrow I think  , West Malling  ME19   area if you are fairly near  . someone there would almost certainly have a look for you . :y
Check out the meetings page
symes
  • oxford
    • R reg 940 volvo
Re: omega heating
« Reply #7 on: 16 November 2012, 21:27:08 »
check water level in expansion tank-if low that could cause problem too if v6 check small vacuum pipes to/from brake servo-they split on plastic T pieces and that stops HBV=no heat
maryso
  • kent
    • omega
Re: omega heating
« Reply #8 on: 16 November 2012, 21:45:14 »
temp gauge ok
maryso
  • kent
    • omega
Re: omega heating
« Reply #9 on: 16 November 2012, 21:46:21 »
thanks for that, top tip, will look up the meeting!! temp gauge ok
maryso
  • kent
    • omega
Re: omega heating
« Reply #10 on: 16 November 2012, 21:47:44 »
4 cylinder
alank46
  • South Devon
    • 3L Elite Estate 1996
Re: omega heating
« Reply #11 on: 16 November 2012, 21:52:47 »
Vacuum is used to turn OFF the heat, so no vacuum equals heat.
Re: omega heating
« Reply #12 on: 16 November 2012, 21:57:07 »
Whip the small vacuum pipe off the top of the HBV, and plug the end of the pipe with a small bolt, leaving the "stub" on the HBV open to air....  see if you then get heat.
If you can't find the HBV pop to the meet and get one of the guys to do it !!!
maryso
  • kent
    • omega
Re: omega heating
« Reply #13 on: 16 November 2012, 22:03:31 »
  i'll give it a go, but more likely to rock up to the meet looking helpless!!!
Marie
    • 2ltr LPG Estate
Re: omega heating
« Reply #14 on: 16 November 2012, 22:29:35 »
Go to the meet chick the lads are sure to help a damsel in distress :-*
Sorry you to far from me otherwise I'd come and have a look for you
