I was having another mooch under the bonnet just now, and noticed there is a couple of, what looks to be, oil leaks, again
, there are no dripping leaks, but it seems to be going through oil like mad, I only do between 300-500 miles a month and im topping it up 1 liter every month. I dont think its burning oil, and there are no drips under the car, so im stuck as to whats going on.
Here are a couple of piccys, first one seems to be coming from the sump breather pipe somewhere and very very slowly, ending up on the exhaust manifold heat shield.
The next one is oil around the throttle body (maybe thats why the spanner light came on the other morning, but dont know)
I believe this is probably the beathers blocked again and need to take them off, clean, and give it an oil and filter change.
On this picture, the small breather pipe that runs to the throttle body was the one that was blocked last time, the others were ok. So, id better take it off and check. I squeezed it and it felt really soft, so does that pipe need replacing?
So, the main question is, why am i topping up 1 liter of oil for every 500 miles driven when there are no big oil leaks.
