Author Topic: misfire  (Read 1525 times)
manolo
misfire
« on: 19 January 2013, 22:44:42 »
Hi
I have to start new topic to avoid confusion
here is my problem:
omega 2.6V6 y26se
only in idle sometimes blink EML light
unstable work in idle, and strange sound from exhaust
errors 0300 0301 0303 0305
so far I do next (with no improvement):
replaced ignition coil 1-3-5 & crank sensor with new one
engine cleaned with motorvac carbon cleaner
injectors removed, cleaned, meashured and switched place 1-3-5 with 2-4-6
2 bottle Wurth - System Cleaner for valve cleaning
sparks have only 1 year and 20000km and looks OK (BOSCH 4 electrode)
tested if it take bad air with start spray
my mechanic suspect to damaged valves
is it possible to be something else?
can O2 sensor cause problem?
symes
  • oxford
    • R reg 940 volvo
Re: misfire
« Reply #1 on: 20 January 2013, 00:46:38 »
do compression test ------- your codes mean cylinder 1+3+5 are at fault so Coil set on 1+3+5 is no good :y
manolo
Re: misfire
« Reply #2 on: 29 January 2013, 07:20:17 »
found that valves don't seal very well
manolo
Re: misfire
« Reply #3 on: 29 January 2013, 09:36:52 »
& How bad is it if the left and right pulleys shifted slightly left and right as in the picture??
Re: misfire
« Reply #4 on: 29 January 2013, 09:55:02 »
You'll be down on power and fuel economy. Worse case scenario is if they are too far you bend the valves. I take it you haven't got the proper cam locking/timing kit then
