Author Topic: Misfire and error codes  (Read 515 times)
viper357
  • Worthing
    • 2001 3.2 Elite
« on: 09 February 2013, 16:09:35 »
Hi guys
I have the following error codes from my car:
0420 cat
0300 random misfire
0306 cylinder 6 misfire
0430 cat
Do you think the misfires would cause the 0420 and 0430 errors?
Also, what are the best spark plugs to use in the 3.2, the four-electrode Bosch ones?
Thanks.
Dean
serek
  • huntingdon
    • 3.2 mv6
Re: Misfire and error codes
« Reply #1 on: 09 February 2013, 20:14:50 »
Hi guys
0420 cat
0300 random misfire
0430 cat
Thanks.
GM spark plugs are best
and cheap too :y
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #2 on: 09 February 2013, 20:29:54 »
Hi guys
0420 cat
0300 random misfire
0430 cat
Thanks.
sometimes supermarket fuel can bring those codes up too :-\
as for the misfire on number 6 cylinder its probably just the plug as i have heard they are a pita to remove (as i have read on a few threads) so may well have never been replaced.
« Last Edit: 09 February 2013, 20:42:21 by noel »
« Reply #3 on: 09 February 2013, 20:31:50 »
Hi guys
0420 cat
0300 random misfire
0430 cat
Thanks.
Unlikely
http://www.omegaowners.com/forum/index.php?topic=90613.0
New POD
  • Miseryside
    • NEED MV6
« Reply #4 on: 04 June 2019, 21:18:13 »
Thread resurrection :
Can I just add
B
A
L
L
S
Engine management light keeps coming on.  3.2 MV6 with 216K on the clock.  I'll have to check next time but there were 4 fault codes.  Can't remember exactly what they were but 0420 and 0430 might have been 2 of them.
 I know that I didn't fit GM spark plugs last service, because erm stupid.  But Car seems to be running fine. Happens when I accelerate hard.  Light Goes off eventually, if I'm tottling down the motorway at 65 mph (as you do when you can't be arsed to drive faster)
Anyway I have to
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #5 on: 04 June 2019, 21:27:33 »
Anyway I have to
read the codes again first  :y
New POD
  • Miseryside
    • NEED MV6
« Reply #6 on: 04 June 2019, 21:39:52 »
Anyway I have to
Indeed.
How much are 6 trade-club 9195868 plugs by the way ?
  • Chatham, Kent
  • Rover Metro 1.8VVC
    • 3.0l Elite estate
« Reply #7 on: 04 June 2019, 21:41:32 »
Can I just add
B
A
L
L
S
Anyway I have to
400 codes aren't misfires, and are really unlikely to be ignition related. As it's a 3.2, you're probably looking at the cat/pre-cat fault that is fixed by moving the top O2 sensors.
Any good quality spark plug(Bosch, GM, NGK) will be fine, GM ones are recommended if you can get them at a good price. I find they're no cheaper than NGK from a local factor, but are more hassle to get so don't bother
« Last Edit: 04 June 2019, 21:43:27 by Nick W »
New POD
  • Miseryside
    • NEED MV6
« Reply #8 on: 05 June 2019, 10:15:45 »
Anyway I have to
Light gone out this morning.  Still I have 1000 miles to do in the next 7 days, so i am sure it will be on again.
biggriffin
  • huntingdon, Hoof'land
    • Vectra in a posh frock.
« Reply #9 on: 05 June 2019, 12:05:48 »
Fill with, a premium fuel, Tesco 99/shell optimal, BP ultimate, new air filter, I did use NGK twin electrodes, for 3.0L, then take it for a good long blast along the motorway, good 40+ miles. or get lamdas moved, there is a guide, or if you can get a pair of 3.0L/2.5 downpipes
Hoof'land storeman..
Rwd-less..
« Reply #10 on: 05 June 2019, 12:32:16 »
Stop using crap fuel and drive it properly. If you're getting more than 25 mpg out of it, then you simply aren't driving it properly  ;D
johnnydog
  • East Lancashire
    • 2.6 & 3.2 sal, 3.2 est
« Reply #11 on: 06 June 2019, 14:12:45 »
Over the last 15 years  of V6 Omega ownership, 95% of the time, I use Morrisons 95 (they don't do 98/99) as its convenient.
Whenever I have had any lights come on or misfires, which is relatively infrequently, it usually has been water in the plug wells, despite following the guide regarding sealing the scuttle....
Although a Tesco with 99 Momentum has opened near us, and having tried it on my older classics, I am impressed with how the old cars run with it, so may give it a whirl.
2002 3.2 Elite saloon, 2003 3.2 Elite estate, 2003 2.6 Elite saloon
Page created in 0.118 seconds with 21 queries.
