Author Topic: Temperature gauge not working!  (Read 3696 times)
nilocp
  • Halifax, West Yorkshire
« on: 01 April 2013, 19:40:13 »
Temp gauge not working at all, but heater OK. What shall I look at first?
Colin
Johnny English
  • Hungary
  • English antitalent
    • 1995. 2.5 V6 LPG manual
Re: Temperature gauge not working!
« Reply #1 on: 01 April 2013, 19:52:41 »
Try this first :
http://www.omegaowners.com/forum/index.php?topic=103147.msg1292594#msg1292594
Good luck with sorting out matey !  :y
C20NE - X25XE
« Reply #2 on: 01 April 2013, 20:00:17 »
Bullet connector on coolant bridge is the first check.
nilocp
« Reply #3 on: 03 April 2013, 20:40:27 »
OK, full story on this now. I have just bought this car, and now have it home. He has had the temp sender replaced and still no gauge.
But, when driving it, the gauge occasionally comes up to about 80, stays there a little while and drops down to nothing again. Everything else seems to be OK.
Lazy thermostat???
Oh by the way, 3.2 MV6 Estate!!
« Reply #4 on: 03 April 2013, 20:42:09 »
Put the palm of your hand on the rev counter, and press firmly. With luck, you may feel the entire cluster move back slightly. If so, it is probably just the cluster wasn't fully seated.
« Reply #5 on: 03 April 2013, 21:18:31 »
Lazy thermostat???
It sounds like the 'stat to me.
To test your gauge, remove the single blue wire that goes to the gauge sender unit (the ECU's temp sender unit is next to it) and ground it. Your gauge should go to fully hot.  :y :y
« Reply #6 on: 03 April 2013, 21:21:03 »
Ah, hang on, does gauge gently creep up to 80C, then gently drop. Or is is sudden?
If gentle, if you leave it idling on driveway for 20 mins, does it creep up higher? If so, stat.
If its sudden, try the cluster trick I mentioned.
nilocp
« Reply #7 on: 03 April 2013, 21:27:17 »
Yes it creeps up, and then slowly drops. I'll try it on the drive tomorrow. :y
« Reply #8 on: 03 April 2013, 21:33:58 »
Thermostat stuck open  ;)
« Reply #9 on: 03 April 2013, 21:37:49 »
While you are "trying it" .. start from cold and stand with your hand on the large pipe that goes from the thermostat to the top of the radiator. That pipe should stay cold and suddenly get a surge of hot water as the thermostat opens after about 5-10 minutes at idle. If it very slowly and continuously warms up all the time then the thermostat is either stuck open or missing completely.
nilocp
« Reply #10 on: 04 April 2013, 18:43:39 »
Bugger bugger!! The damn gauge is working today!
I'll have to keep my eye on it.
Colin
