Author Topic: lock set  (Read 2348 times)
swordfish
  • manchester
    • 3.0 omega elite fl / 2000
lock set
« on: 12 May 2013, 21:37:06 »
Anybody got a lock set for a facelift elite .
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
Re: lock set
« Reply #1 on: 14 May 2013, 16:18:41 »
got one for a vectra 2.5 with 2 keys and car pass if any use and if it will fit,also has ecu, key reader from round barrel and central locking ecu, came from a estate i broke, 40 quid the lot
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
twiglet
  • Norwich, Norfolk
Re: lock set
« Reply #2 on: 14 May 2013, 20:06:24 »
Saloon or estate mate?
swordfish
  • manchester
Re: lock set
« Reply #3 on: 16 May 2013, 20:30:35 »
2000 elite saloon
twiglet
  • Norwich, Norfolk
Re: lock set
« Reply #4 on: 17 May 2013, 08:01:42 »
Might be able to find you something at the weekend mate.  Is it just the key blades, ignition and drivers door barrels you need?
swordfish
  • manchester
Re: lock set
« Reply #5 on: 18 May 2013, 07:19:10 »
well basically ,the problem is i have lost the key. i do have a spare key but who knows were the other one is >:( . so i need to change both fob and locks . whats the best way to go about it . thanks carl
Re: lock set
« Reply #6 on: 18 May 2013, 09:31:41 »
It might not be the cheapest way, but the easiest way is to get another key. When the new key is coded up, Tech II tells the car to ignore the old/lost key. If it subsequently turns up, it can be coded back up to the car.  :y
