Pages: [1] 2 3 4 5 6 7 8 ... 11   Go Down
Author Topic: CID in "full" use  (Read 56148 times)
kcl
  • Finland
    • Volvo V60 D4 -14
CID in "full" use
« on: 13 May 2013, 12:06:22 »
How on earth did they manage to do this... http://www.youtube.com/watch?v=HMSa48yOGGE
I want one too! Most of the original functions (not sure about satnav), reversing camera display AND the movies...  :'(
Re: CID in "full" use
« Reply #1 on: 13 May 2013, 12:10:25 »
They add a small interface device between the CID processor and the LCD panel.
This allows you to squirt other feeds into the unit such as reversing camera and TV feed
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 13 May 2013, 12:11:59 »
Probably just fed RGB or what ever the format is in to the screen via a switch or reed.
Iain
« Reply #3 on: 13 May 2013, 13:14:49 »
Quite like the reversing camera  ;D
« Reply #4 on: 13 May 2013, 14:15:33 »
I'd like those features, how easy is add said "small interface device" ?
zirk
  • Epping Forest
« Reply #5 on: 13 May 2013, 14:45:03 »
Theres a "How To" or more like a "How I did it" or one of the German Forums kicking around somewhere from memory. Looked into myself a few years back, and decided it was too much hag for the desired result.  ;)
Tiefer
  • Spain
    • 2.6 Elegance
« Reply #6 on: 13 May 2013, 17:51:12 »
This car has fiited an interface with a switch so you choose what do you want to see. The rev camera view switches on with the rev sensor in the gear stick.
The guy that sells the interfaces also repairs the common CID problems (stripes, blank screen) very cheap.
That is the car of a mate. He has an iPod connected to the interface.
Cheers
reinoso
  • Spain
« Reply #7 on: 13 May 2013, 23:05:18 »
Hello,
I'm the designer of that interface. It allows one RGB input and two composite. One part of the interface is installed inside the CID:
We managed to get Windows mobile in the native resolution:
But right now we've found the Android much more interesting ...
So we're developing an Android GPS box compatible with the low res. stock navy displays, including the Opel 4:3 CID.
Regards.
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« Reply #8 on: 13 May 2013, 23:38:29 »
Looks interesting.Keep us up to date with your work
zirk
  • Epping Forest
« Reply #9 on: 14 May 2013, 11:31:05 »
Hello,
Regards.
Thats somewhat different and a lot neater than the one I saw on the German Forum, looks tidy  ;) the Android bit is interesting. keep us informed.
How do you plan to control the Touch Screen feature of the OS?
SkyHighatrist
  • Wolverhampton
    • Omega 2.5 V6 Elite
« Reply #10 on: 14 May 2013, 12:04:03 »
That reverse camera does look mighty fine  :y
think I may be adding to my, already very early, Christmas list  ;D
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #11 on: 14 May 2013, 14:59:49 »
Reverse camera on an omega? Whats wrong with good ol MK 1 eyeballs.
Hoof'land storeman.
reinoso
  • Spain
« Reply #12 on: 14 May 2013, 15:51:22 »
In the Vectra B/omega as you know there is a plastic cover in the dashboard, so it is not possible to add a resistive touch panel (unles you make a cut in this plastic, leaving the speedo needles 'exposed' and not very esthetic ...). But using a touch pad or trackball through USB is perfectly possible, Android 4.2 natively supports HID peripherals.
This is the prototype installed in my car (Saab 93 SS). The stock navy screen is 400x234, only a bit more vert. resolution than the CID screen (320x234).
https://www.youtube.com/watch?v=ZQasY-bS7UQ
« Reply #13 on: 14 May 2013, 16:08:53 »
Very interesting  :y - What is the Android device?
Have you considered a Raspberry Pi?
Is this something you would do as a service? Quite a few people here have CID's myself included, I'm sure there would be considerable interest this CID upgrade.
What kind of cost would we be looking at for a CID to have the RGB input and two composite added?
As above keep us updated, looks very good  :y :y
reinoso
  • Spain
« Reply #14 on: 14 May 2013, 16:29:35 »
We're developing a complete device, based in ARM like raspberrypi but more powerful.
It comes with:
- Android 4.2
- GPS
- 4x USB Host
- Internet 3G (HSDPA)
- GSM
- 2x composite video input
- RGB/VGA output
All fully integrated in a small device of 100x120x30mm.
We hope it will be available in summer (probably August).
I would need a certain number of orders of the 4:3 CID video interface, that will allow the connection of the Android box, to make it worthwhile. In the Saab 93 forum I designed and produced the stock screen interface, but there were a lot of people interested.
Pages: [1] 2 3 4 5 6 7 8 ... 11   Go Up
