Author Topic: LSD  (Read 2853 times)
bigegg
  • Leeds
    • MV6 RIP - Lexus GS300 '99
LSD
« on: 21 May 2013, 19:18:58 »
How can I tell if my 3.0 MV6 ('98 mFL) has a LSD?
Carpe Incendium
Re: LSD
« Reply #1 on: 21 May 2013, 19:41:05 »
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: LSD
« Reply #2 on: 21 May 2013, 22:17:39 »
Also check to see if the pupils are dilated.  If so your car is triiiiiippppin!  ;D ;D
2woody
  • Northumberland
Re: LSD
« Reply #3 on: 21 May 2013, 23:16:46 »
WITH A DRIVESHAFT REMOVED, look into the output hole where the driveshaft pops in, if there is one cross-shaft keeping the planet wheels apart, then its an open diff. If there's a pair of crossed shafts visible, then its LSD.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: LSD
« Reply #4 on: 22 May 2013, 09:26:01 »
if your car is stuck in a lift and thinks the lift is on fire that's a sure sign  ;D ;D ;D
RIP Paul Lovejoy
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: LSD
« Reply #5 on: 22 May 2013, 16:19:49 »
Fair chance if it was Ex Police, near zero chance if not, Most Ex Plods had Calibrated Speedo sticker on the Clock.
Sometimes difficult to tell when just driving the car if its not fitted, bloody obvious though when LSD is fitted and licks in.  ;)
« Last Edit: 22 May 2013, 16:34:54 by zirk »
bigegg
  • Leeds
Re: LSD
« Reply #6 on: 22 May 2013, 16:34:04 »
Not ex-police, but "modified" by a previous owner, so is a possibility
Carpe Incendium
zirk
  • Epping Forest
Re: LSD
« Reply #7 on: 22 May 2013, 16:42:57 »
Easiest way to tell for sure without climbing under the car is one wheel on grass or gravel the other on tarmac, TC off, loud pedal from stationary. Non LSD will just spin the wheel on the grass, LSD fitted, your be off like a shot leaving tell tale marks behind you whilst trying to control your car in a straight line and probably start wondering why you took this test in the first place.  :y
bigegg
  • Leeds
Re: LSD
« Reply #8 on: 22 May 2013, 17:06:26 »
That would work.
If my car did  :'(
I'm at the point of stripping her for spares, and wondering if it was worth keeping/selling the diff.
Carpe Incendium
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: LSD
« Reply #9 on: 23 May 2013, 13:49:45 »
Lsd thread. Getting like tyre thrads but not as vocal.
Hoof'land storeman.
martin42
Re: LSD
« Reply #10 on: 23 May 2013, 16:29:49 »
Has the search feature stopped working  ::) ::) ::)
bigegg
  • Leeds
Re: LSD
« Reply #11 on: 23 May 2013, 16:48:14 »
yep.
HTH.
HAND.
Carpe Incendium
