Author Topic: Brake light Madness  (Read 2163 times)
gazza57
  • Liverpool
Brake light Madness
« on: 21 May 2013, 20:51:15 »
Hi,my brake light warning came up on the display so I changed the offending bulb on the left and the other side next time I drove the car the warning was up again.I asked a friend to tell me which side was out he said the left so I changed it again,driving home from work you guessed it brake light warning again on the left. Whats happening???
Re: Brake light Madness
« Reply #1 on: 21 May 2013, 21:10:09 »
Shit bulbs?
« Reply #2 on: 21 May 2013, 21:18:52 »
TBs right - paticularly if you got them from Halfords!!
Generally Vx or Ring bulbs ok - there may be others too, but not Halfords ;)
symes
  • oxford
    • R reg 940 volvo
« Reply #3 on: 21 May 2013, 21:20:47 »
Halfrauds ;)
« Reply #4 on: 21 May 2013, 21:21:29 »
Halfrauds ;)
;D ;D
symes
  • oxford
    • R reg 940 volvo
« Reply #5 on: 21 May 2013, 21:28:07 »
mate had same problem on his Alfa--he went to Halfrauds too ::)
Moral is Do not get bulbs from----Halfrauds :y
tommy mac
  • Chippenham, Wilts
    • 2.2 CD Omega
« Reply #6 on: 22 May 2013, 15:44:15 »
I had a similar frustration but it turns out not to be the bulb.  The bulb holder was the problem, in particular the metal strip at the bottom of the holder that makes contact with the bulb had become flattened rather than standing proud to act as a spring and ensure contact with the bulb.  Worth a look.  I just lifted the metal up slightly with a pair of long nosed pliars.
Tom
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #7 on: 22 May 2013, 22:25:49 »
I believe the brake light warning system is a reed relay which compares the current taken by the two stop light bulbs. I imagine Halfords bulbs differ from other makes by enough to trigger the reed relay. So If you buy at Halfords, but 2 bulbs and change them both.
« Reply #8 on: 22 May 2013, 22:33:15 »
They're cheaper from Vauxhall as well :y
« Reply #9 on: 23 May 2013, 00:17:10 »
Thats what the op did - changed them both ;)  But op has not responded to make of bulbs fitted.
gazza57
  • Liverpool
« Reply #10 on: 26 October 2013, 13:32:43 »
Sorry can;t remember the make,anyway its all sorted now.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #11 on: 26 October 2013, 19:31:32 »
So how was it sorted?
