Author Topic: Weird noise  (Read 3226 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Weird noise
« on: 22 May 2013, 23:21:00 »
Ok, after lots of buggering about, the car is running on LPG and running very nicely  :y  :y :y :D :D :D
But true to form, the car has developed a weird noise while accelerating.
It seems to be coming from the drivers side of the engine bay.
You can also feel a vibration threw the accelerator peddle.
The only way I can describe it is it sounds like a power steering  pump which is low on fluid.
Should add that the LPG reducer is bolted to the inside of the wing on that side.
Reducer gas pressure is a tad low (1 bar) but the car revs to 6000 rpm plus with no errors recorded or hesitation  :y
Any ideas please  :)
allen25
  • Worcestershire
    • Omega 2.6 V6 2001
Re: Weird noise
« Reply #1 on: 23 May 2013, 11:14:18 »
I don't have the answer but have been thinking about what you've said. Is the noise specific to LPG or happening on both fuels?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Weird noise
« Reply #2 on: 23 May 2013, 11:40:04 »
Good point Allen  ::) :-[
Its happening when running on gas only I believe.
Running on petrol vapours at the moment so not in a position to compare when hot until later.
Also the hotter the coolant, the nosier is seems to get.
Only happens when the engine is under load and the noise seems to disappear above approx. 4000 rpm.
Re: Weird noise
« Reply #3 on: 23 May 2013, 11:44:13 »
Is everything tightened up as it should be? When was the cambelt/waterpump last changed... bit of play somewhere :-\
Does it happen at the same engine speed in each gear, or is it related to road speed?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Weird noise
« Reply #4 on: 23 May 2013, 12:08:16 »
Everything seems nice and tight.
With me being a ham fisted barsteward, things are liable to be over tight
Cambelt / waterpump should have another 15K / 18 months left (if the service documents are to be believed)
The car was bought as spares or repair as a project for me to tinker with.
Noise seems to engine load related.  In other words, the harder I stamp on the gas peddle, the nosier it is until around 4K revs when it disappears
« Last Edit: 23 May 2013, 12:09:55 by tigers_gonads »
Re: Weird noise
« Reply #5 on: 23 May 2013, 12:51:52 »
It's not the regulator vibrating is it ?? As there's a diaphragm inside it's a possibility .... ?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Weird noise
« Reply #6 on: 23 May 2013, 13:09:16 »
With the gas pressure a little low  :-\
mmmmmm
Could be.
With the vibration being transmitted threw the inner wing and peddle box  :-\
i'll get my hand on it and  if I can feel anything later when it stops raining  :y
Also, the plenum has been off / throttle body's water pipes have been off a fair few times over the last week.
I'm wondering if I've a little bit of air in the reducer  :-\
Re: Weird noise
« Reply #7 on: 23 May 2013, 13:27:15 »
mmmmmm
Could be.
Try running it for a while with the cap off the coolant bottle and the cabin temp set to Hi on both sides. Should make sure there's no air in the system, just to rule it out :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Weird noise
« Reply #8 on: 23 May 2013, 13:28:46 »
mmmmmm
Could be.
Will do  :y
Re: Weird noise
« Reply #9 on: 23 May 2013, 13:32:34 »
mmmmmm
Could be.
Will do  :y
A few hard squeezes on the large hose whilst doing that might help as well .. it tends to shift any airlocks or stubborn bubbles :)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Weird noise
« Reply #10 on: 24 May 2013, 20:51:27 »
Right, now confirmed it the reducer that's squealing  :(
Engine is smoother then a babies bottom when running on petrol.
Also i've got a faint smell of gas but that may be a pipe  :-\
System well and truly burped so pretty sure there is no air in there.
The reducer is a KME Gold.
Has anybody on here had any problems with theirs ?
Squealing or other wonderful noises ?
I've also had a good sniff of the coolant bottle.
I can't smell any trace of gas so I presume its not leaking gas into the coolant.
Edit to say ................ it only happens when its warmed threw
« Last Edit: 24 May 2013, 20:56:48 by tigers_gonads »
  • Auckland
    • Mazda MPV
Re: Weird noise
« Reply #11 on: 25 May 2013, 12:40:23 »
How rigid is the support of the vapouriser? If it is a bit springy it might be resonating. I would try providing a more rigid support. If that doesn't work, rubber mounting the vapouriser to isolate the vibration from the car body.
