Author Topic: Martin Imber  (Read 5228 times)
kevinp58
  • kent
    • 2002 3.2 elite
Martin Imber
« on: 19 August 2013, 22:02:33 »
Got my key back today from Martin, he redid the switches for me.  :y very quick service and didn't even have to re- sync the key to car it all worked great. Once again many thanks I highly recommend his services.  :y :y
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Martin Imber
« Reply #1 on: 20 August 2013, 00:23:45 »
Yep, top bloke and great service  :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Martin Imber
« Reply #2 on: 20 August 2013, 00:28:24 »
Sounds good  :y
How much if you don't mind me asking mate ?
The button that unlocks is a little temperamental on the Elite
Re: Martin Imber
« Reply #3 on: 20 August 2013, 17:58:56 »
Sounds good  :y
Get is changed before you destroy the rubbers.
If you're handy with a soldering iron, I think the switches are available in the shop.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Martin Imber
« Reply #4 on: 20 August 2013, 19:02:46 »
Sounds good  :y
Is there a guide on how to do this i wonder ?...
I could give it a go with an old Omega key I've got but I'm not sure about soldering such small things..
How much does Martin charge roughly if he's reasonable i'll let someone who knows what their doing to do the job properly.
kevinp58
  • kent
    • 2002 3.2 elite
Re: Martin Imber
« Reply #5 on: 20 August 2013, 19:27:22 »
He charges £12 for switches £17 with covers.  :y Link here www.imber.me.uk/keyfob.htm
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Martin Imber
« Reply #6 on: 20 August 2013, 19:32:00 »
What is the rubber like compared to the original, Harder ?
My cover is fine to be honest, Just say the lock and unlock switches need changing but might as well change all 3  :-\
kevinp58
  • kent
    • 2002 3.2 elite
Re: Martin Imber
« Reply #7 on: 20 August 2013, 20:15:16 »
He only did my switches I had already got spare covers
Re: Martin Imber
« Reply #8 on: 20 August 2013, 21:59:07 »
All the replacement covers I have come across are pretty hard TBH.
The soldering is pretty easy if you've ever soldered small stuff before. It is surface mount, but quite large for SM, so a small iron and steady hand are needed.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Martin Imber
« Reply #9 on: 20 August 2013, 22:09:47 »
I have something like this
For under £4 delivered for 3 switches ain't bad at all, Who will be dispatching them if i buy from OOF shop, Estimate delivery period  ?
« Last Edit: 20 August 2013, 22:13:27 by Mr.OmegaMan »
Re: Martin Imber
« Reply #10 on: 20 August 2013, 22:15:29 »
Hard to tell how suitable, what is the tip like?
Who will be dispatching them if i but from OOF shop,
One of the shop admins
Generally dispatched within 48hrs by the chosen method. Obviously, if we're all at Newent, for example, then there will be a delay in dispatch.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Martin Imber
« Reply #11 on: 20 August 2013, 22:19:03 »
Thanks TB,
Will check the tip type on mine before purchasing, Also have a gas one with a sharp tip but that gets too hot quickly...
Sounds promising though  :y
Re: Martin Imber
« Reply #12 on: 21 August 2013, 18:02:04 »
Thanks TB,
I'd not use a gas one, a bit too uncontrollable for this application.
Re: Martin Imber
« Reply #13 on: 21 August 2013, 18:55:17 »
I agree, Martin has revamped a number of my fobs and always provides a first class service :y :y :y :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Martin Imber
« Reply #14 on: 22 August 2013, 14:57:36 »
Ive used the Gas type (RS) on Fobs, just turn the heat down a bit after its warmed up. What is imperative is a good clean tip, good solder, wet sponge and a decent solder sucker.  :y
Page created in 0.018 seconds with 14 queries.
