Author Topic: 3.2 V6 Thermostat  (Read 3578 times)
3.2 V6 Thermostat
« on: 23 October 2013, 14:43:52 »
Where's the best place to buy from? Any pattern recommendations?
VX non stock and £78 + Vat :-\
Re: 3.2 V6 Thermostat
« Reply #1 on: 23 October 2013, 14:53:02 »
Mine was from AndyC and a lot cheaper than that on TC IIRC.. unless they have gone up?
« Reply #2 on: 23 October 2013, 14:54:45 »
Hmmm :-\ that was/is full retail...
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #3 on: 23 October 2013, 15:22:49 »
last time Daz was down doing on of my Cam Belts, had to go and get one on the quick, so it was from the local Factors, £50 odd quid retail, and after moaning walked out with it for £35 inc Vat trade.  ;)
« Reply #4 on: 23 October 2013, 15:37:59 »
Elite pete recommended a brand to me,who apparently supply them to GM. Cant quite remember the name. Maybe Mahle or similar ?
Might be worth asking Pete. I used genuine GM  when I did my own car,but got it at a one off bargain price at the time.
amba
  • Medway towns
    • German V6
« Reply #5 on: 23 October 2013, 16:17:04 »
I used one of these on advise from forum admin about 18 months ago...251346508408...and it has served me well since.
Even the housing was the correct thickness so no need messing about with cutting bolts although unsure if 3.2 housings are sligthly different thickness from my 2.5
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #6 on: 23 October 2013, 16:35:53 »
Got mine from Vauxworld. Made by Wahler, who clearly were the original supplier. It was identical to the GM part I removed, including the casting flash, part number and someone had made a very half-hearted effort to remove the GM logo.
Under £20 delivered.
« Reply #7 on: 23 October 2013, 17:00:44 »
Thanks all :y
The Vauxworld p/n ( 90502201 )is different to the one given by the dealer (55353492) ::) possibly due to being a later engine :-\
Have put the part number given into Google, which led me to a GM dealer in Florida, $67 (£47) including tax and post, which is, I think, a fair price for a genuine one...
« Reply #8 on: 23 October 2013, 17:02:04 »
Wahler are indeed one of the (two) original suppliers.....each supplier has a different thickness flange (and hence the issues we see with bolt length sometimes).
For me, the Wahler ones appear better and have a much better housing to block seal setup on them
Edit, checked my notes and Motorad are the other supplier (adn the ones with the thinner flange)
« Last Edit: 23 October 2013, 17:04:34 by Fuse18 »
« Reply #9 on: 23 October 2013, 17:12:38 »
Any views on AC Delco :-\
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #10 on: 23 October 2013, 17:22:57 »
Had one from another supplier was a wahle one,no differences between,this and a genuine, just the GM number had been sanded off the wahle part. Came with o ring.
 note new o rings for transfer pipe as well. :)
Hoof'land storeman.
« Reply #11 on: 23 October 2013, 17:46:47 »
Transfer pipe and O rings on order, £20 all told :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #12 on: 23 October 2013, 17:50:13 »
Yes Wahler is the same as gm Just gm marking filed off
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #13 on: 23 October 2013, 17:59:34 »
Don't forget a new b*&@#d bolt to replace the one you lose . ::) ::) ::)
biggriffin
« Reply #14 on: 23 October 2013, 18:30:39 »
think its a std M8 bolt about a 35 i think.
Hoof'land storeman.
Page created in 0.023 seconds with 20 queries.
