Author Topic: 2.6v6 crankshaft?  (Read 6253 times)
husky12
  • derry
    • omega 2.5 v6
2.6v6 crankshaft?
« on: 02 November 2013, 17:04:06 »
i have a 2.5 v6 and the timing belt snapped and wrecked the engine. i got a 2.6 bare engine and changed every thing from my 2.5 on to it and fitted it. its messing about going then stopping again and was wondering should i use the 2.5 sensor because the brain is 2.5 or the 2.6 sensor because of the engine? cheers
omegod
  • liverpool
    • 2017 Seat Ateca
Re: 2.6v6 crankshaft?
« Reply #1 on: 02 November 2013, 17:44:50 »
Don't know the answer but have a 2.6 ecu and chip/ key set for sale if needed
« Reply #2 on: 02 November 2013, 18:01:27 »
2.6 sensor assuming same number of wires :y might need a tail of loom to connect it as the plug might not fit :-\
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #3 on: 02 November 2013, 20:01:42 »
If the 2.6 was undressed and you redressed it with all of the 2.5 sensors,it should run. Only problem would be the Sai system as a 2.6 dosnt have a egr/sai system.
 so i would thing your crank sensor on the way out..
Hoof'land storeman.
husky12
  • derry
    • omega 2.5 v6
« Reply #4 on: 05 November 2013, 02:01:45 »
just keeps putting up hall sensor high voltage? any thoughts
biggriffin
« Reply #5 on: 05 November 2013, 09:30:15 »
Crank sensor,knackard
Hoof'land storeman.
« Reply #6 on: 05 November 2013, 13:20:19 »
"Hall Sensor" is the camshaft sensor, not the crank sensor, if memory serves, although neither is actually a Hall sensor. ::)
Can you get the numeric code from the code reader, as I suspect it's just giving you a generic description?
Crank sensor is P0335. Cam sensor is P0340. :y
You can just do the pedal trick to verify this.
« Reply #7 on: 05 November 2013, 13:25:44 »
Could be a compatibility issue... Car built as a 2.5 which went bang. Engine replaced with a 2.6 lump running 2.5 sensors and management. Pedal trick won't work, paper clip might :-\
« Reply #8 on: 05 November 2013, 13:27:37 »
Yes, of course, it'll be the old management so paper clip test.
husky12
  • derry
    • omega 2.5 v6
« Reply #9 on: 10 November 2013, 19:02:10 »
paperclip test?
  • Auckland
    • Mazda MPV
« Reply #10 on: 10 November 2013, 19:12:00 »
  • Auckland
    • Mazda MPV
« Reply #11 on: 10 November 2013, 19:16:13 »
You should use the sensors that match the ECU you are using.
Crank sensor wiring runs close to the exhaust manifold and goes brittle in use. It is quite likely that yours has failed as a result of being disturbed.
A faulty crank sensor doesn't always bring up a code. Both the failures I have had gave no codes >:(
husky12
  • derry
    • omega 2.5 v6
« Reply #12 on: 10 November 2013, 19:28:10 »
i am using the 2.6 crank sensor and is starting and idling fine now. the  3 earths at back of engine had came lose somehow.now its starting but wen you accelerate its missing an choking like mad, and takes a wile to build revs. if you slowly accelerate its dosnt seem to be ass chokey  but still misses, im gonna read the codes tomorrow but any ideas?
darrenfos
  • eastleigh
    • omega elite manual
« Reply #13 on: 10 November 2013, 19:47:34 »
sounds like a idle valve or throttle position sensor
omega is like marmite you know the rest
« Reply #14 on: 11 November 2013, 00:39:47 »
No ICV on a dbw engine ;)
