Author Topic: Heads up re; fuel pump cover plate  (Read 1786 times)
« on: 11 November 2013, 16:14:34 »
Having discovered one of the pipes corroded & leaking on the fuel pump cover plate, phoned around and discovered that there are only 3 in the country and all at the Luton factory. Obviously there`s only 2 left now ::) so if anyone wants to check their pipes for possible corrosion I`d advise doing so now.
MR MISTER
Re: Heads up re; fuel pump cover plate
« Reply #1 on: 11 November 2013, 16:15:41 »
Mark will simply manufacture a couple of dozen. ::)
« Reply #2 on: 11 November 2013, 16:17:06 »
Not seen this happen for a while, we were advising greasing this area some time ago.
amba
  • Medway towns
    • German V6
« Reply #3 on: 11 November 2013, 16:22:30 »
Glad to hear you are sorted Rob  :y
Bit like my saga with the rear brake pad retaining pins for the vented discs..none in the UK and 2 weeks from Germany  >:(
Suppose grease may prolong their life although being a flat surface its easy to see why they rust at the base.Possible a tick coat of Tetraseal  ;)
