Author Topic: The plot thickens on my 2.2DTi Hearse....  (Read 3284 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« on: 12 November 2013, 15:09:26 »
Following on from my original thread... http://www.omegaowners.com/forum/index.php?topic=117760.0
Car went back into my mates garage for a 'Diesel Expert' to investigate the irregular boosting issues further, Diesel expert tested all systems, vac ok, turbo ok, found faults with the MAF & air intake temp leaving error codes.  Faults cleared and new items fitted - issue still exists so old items refitted. Next step is ECU testing :-/ Back to square 1....
Any comments/thoughts welcome as I'm getting miffed now  :-\
P6UL K
  • Dartford, Kent
Re: The plot thickens on my 2.2DTi Hearse....
« Reply #1 on: 14 November 2013, 11:15:42 »
77 views but no comments?
This must be a first!  :D
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 14 November 2013, 11:27:31 »
Would come up with some suggestive comments if I could Paul, but know bugger all about the 2.2 Dti's  ;)
« Reply #3 on: 14 November 2013, 11:35:35 »
Need a tech2 session ?  :-\
andymp
  • Wakefield, UK
    • 2003 Omega CD 2.2 dti Est
« Reply #4 on: 14 November 2013, 13:58:32 »
Are the vacuum solenoids piped up correctly? Theres a diagram somewhere on the net. Look for 2.2 dti vacuum routing. You really need diagnostic to see if its commanding boost.
Artificial intelligence is no match for natural stupidity...
« Reply #5 on: 14 November 2013, 14:16:19 »
Iirc sometimes it comes on boost,sometimes not. ;)
« Reply #6 on: 14 November 2013, 14:17:59 »
Iirc Twiglet was selling one of these a while back ? Might still have it.
P6UL K
  • Dartford, Kent
« Reply #7 on: 14 November 2013, 14:25:18 »
I bought this off of Twiglet! Are you having a blonde moment? Lol
P6UL K
  • Dartford, Kent
« Reply #8 on: 14 November 2013, 14:31:33 »
Well there is a question, all the solenoid's have been replaced and all vacuum tubing has been renewed along with connectors. Whether or not everything is as it should be remains to be seen, I replaced everything in the same way it was on the car already - But I'm led to believe that it has been fiddled with by people in the past.
Finding an accurate layout of the vacuum routeing would be brilliant but the ones I can find seem different to what is on the car
« Reply #9 on: 14 November 2013, 17:33:06 »
Wrong thread. I was replying to a question about a dog guard.  :-[ :-[ ;D ;D
P6UL K
  • Dartford, Kent
« Reply #10 on: 02 December 2013, 16:06:46 »
So a little update, for the countless consecutive Mon & Tues in a row the car is back in the garage having the Auto Electrician play with it and his Vaux-Com after the Diesel expert pretty much didn't have any idea apart from a possible ECU issue?
So last week the AE diagnosed the boost pressure sensor on the inlet manifold, bought new from VX, replaced but issue still pursists.  So today its having a new MAF from VX as the current one won't read any higher than 500 (I'm guessing its reading would be afm?) when underload.
I do have an vacuum guide from Andy which i will use to double check all pipes are in the right places.
Watch this space for further intriguing updates lol
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #11 on: 02 December 2013, 16:23:56 »
I have a ECU here if you have to go down that way and an engine with fuel pump with only 48,500 miles on it :y
P6UL K
  • Dartford, Kent
« Reply #12 on: 10 December 2013, 00:59:17 »
I'll let you know Joff, thanks!
AndyStobbs
« Reply #13 on: 11 December 2013, 23:07:06 »
Find somebody to check the actual vacuum reading at idle. Verify the brake servo isn't leaking vacuum away. Blank if required and drive cautiously in a quiet area away from hazards etc. Etc. Etc. Brakes will be hard without servo.
Had a leaking servo on a vectra dti that caused EGR faults and limp mode due to P0400.
Could your times when boost is unavailable be related to brake applications?
I can't remmber how well the vacuum pump on the vectra performed (I work on a lot of cars, most with horrid problems) but think it was 22inches vacuum at idle after the servo was changed and only 16inches mercury with the duff servo.
