Pages: 1 2 3 4 [5] 6 7 8 9   Go Down
Author Topic: Brake upgrades...  (Read 36083 times)
Re: Brake upgrades...
« Reply #60 on: 09 December 2013, 23:18:28 »
You say that Mr Bear, but the brakes simply don't dissipate the heat quickly enough to cool off between roundabouts :-\
Fair enough. But we're still talking about this happening under heavy braking htough?
Moderate, and from relatively sensible speeds. If I drive from Horsham to Crawley with passengers at 65 and back again at 75, that's 23 roundabouts in 16 miles over 25 minutes. The front discs will be groaning before I'm halfway back...
Hence the desire to improve matters :-\
When I drove to Cambridge there were loads of roundabouts on the A45 straight there. I cant tell you exactly how many.... but I was driving sensibly. and my brakes were fine.
I trust you haven't got a sticking calliper or owt like that?
MoTd every 6 months, fluid changed regularly (Dot5), as are discs and pads. Brake machine shows brakes are balanced and effective, all four wheels going to 1 o'clock on the gauges. 0 is at 7 o'clock btw. :y
chrisgixer
« Reply #61 on: 09 December 2013, 23:23:07 »
Ok, taste aside, but it's not good to be so far away from the average level of force applied at the pedal in other cars.
Plus, I just remembered, there is an entry in Tis regarding servos. Later models have a servo with an extra valve that gives more assistance under emergency braking conditions. Now, if that's not an admission of some level of guilt or desire for more assistance, I don't know what is.
It does take some getting used to, but I had a mk1 mondeo, and the brakes where stonking in that. Once over the whamo at what seems like the slightest touch, the first time their used.
In fact the new Astra vxr is very similar, as the sales rep complained of whip lash at the first junction on the test drive. ;D
« Reply #62 on: 09 December 2013, 23:27:32 »
Has anyone owned their Omega from new? Has the feel of the brakes deteriorated over time?
Wondering if an upgrade or refurbishment of the master cylinder might be in order :-\
« Reply #63 on: 09 December 2013, 23:34:48 »
I've had brand new Omegas, and the brakes were always "defined" as progressive, ie as you braked harder, more servo assistance came into play, unlike Fords where max servo assistance immediately on brake application.
Would have thought on a car of the Omegas age, a refurb of the brake master cylinder, wheel cylinders and repacement flexis can only help, along with a complete brake fluid change.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #64 on: 09 December 2013, 23:36:53 »
Thing is though if ETA's had the brake balance tests and everything is working properly where does he go with that?  :-\
RIP Paul Lovejoy
« Reply #65 on: 09 December 2013, 23:40:26 »
May well be working well enough to pass MOT, but not possibly working at maximum potential efficiency ;)
« Reply #66 on: 09 December 2013, 23:41:23 »
Bigger discs, better pads, braided lines and an overhauled master cylinder...
So the impression of a lack of decisiveness is designed in :-\
« Last Edit: 09 December 2013, 23:43:11 by ex taxi al »
« Reply #67 on: 09 December 2013, 23:42:45 »
A bit coincidental that they're all evenly matched/worn...or is it :-\
« Reply #68 on: 09 December 2013, 23:47:01 »
Apparently so - was advised this when I trial drove my first Omega back in 1996.
Would expect reasonably even wear of similar components over a large number of years, I guess
Webby the Bear
  • Northampton
« Reply #69 on: 09 December 2013, 23:47:20 »
It seems you have a problem somewhere.... break fade with normal braking in a passenger car  :-\
RIP Paul Lovejoy
« Reply #70 on: 09 December 2013, 23:52:08 »
Possibly at the human interface level :-X
That said the ABS only kicks in on snow, so perhaps I'm simply not pressing the pedal progressively enough :-\
All the calipers and brake lines are original.
Webby the Bear
  • Northampton
« Reply #71 on: 09 December 2013, 23:58:25 »
I know you're far more experienced than me mate but have you serviced the brakes... i.e. had calipers off and made sure everythings moving smoothly, calliper, slides etc? I suppose if there were a caliper problem youd know as it would be pulling to one side...
RIP Paul Lovejoy
« Reply #72 on: 09 December 2013, 23:58:42 »
Have to say when I bought my TR4A, the brakes were perfectly adequate for a TR of that age.  For the rebuild I replaced all seals in master cylinder and calipers, fitted new rear cylinders (drum brakes at rear, cylinders lightly scored), and replaced all flexis, together with new pads and shoes.  The improvement was very evident - even more so when I fitted an overhauled servo from a landcrab!
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« Reply #73 on: 10 December 2013, 00:02:01 »
Interesting thread...
FYI... I'm running high carbon Brembo discs, yellow stuff pads - Front, red on the rear, DOT 5.1 and Goodridge hoses all round.... Stops MUCH better than the OEM set-up BUT chuck in a few roundabouts and even the standard sized carbon discs start to give up the ghost  :-\
« Reply #74 on: 10 December 2013, 00:06:51 »
So what were concluding is that a more efficient set up is needed to improve the usability/fade resistance :-\
In other words, well worth pursuing...
Pages: 1 2 3 4 [5] 6 7 8 9   Go Up
