Author Topic: List of trade club parts and prices.  (Read 1744 times)
chrisgixer
« on: 02 February 2014, 23:12:21 »
For those that want to know TC prices, and those that have TC access, or those that want to compare prices and make an informed decision, or find part no.s
If you look up a tc part and price, copy and paste the info here. Then members can decide what parts to go for and where from.
If successful, maybe it could be made a sticky. So no peshin about, right!   >:( ;D
Obviously make a note of the date of the post, as prices do change. :)
If searching numerous parts, you may prefer to "check wishlist" and copy the wishlist contents page. Saves numerous posts. :)
(Bare in mind copying doesn't paste the headings quite over the correct item. You may need to count left to right to get the details of what it all means)
ALL PRICES PLUS VAT!
« Last Edit: 02 February 2014, 23:25:28 by chrisgixer »
chrisgixer
Re: List of trade club parts and prices.
« Reply #1 on: 02 February 2014, 23:12:37 »
ALL
Fluids
Application    Description    Part No.    Retail    Trade    Trade Club   Remove
All    Antifreeze and summer coolant; 5 litres    93165162    £16.05    £14.05    £12.62
Oil
All    Semi synthetic 10W40 - SL/CF A3/B3 GM6049M; 5 litres    93165216    £33.50    £24.57    £13.82
OMEGA ('94-'03)
Timing Belts, Chains, & Kits
2.6i 24v - Y26SE    Timing Belt Kit; (Eng.>) 8578512    93172354    £149.00    £134.10    £118.15
Brake Kits
3.0i 24v V6 - X30XE    Brake Disc Kit; Front; Ø 296 x 28mm; Vented    93175466    £122.00    £100.71    £89.71
chrisgixer
« Reply #2 on: 02 February 2014, 23:24:53 »
Batteries
3.2i 24v V6 - Y32SE    44 AMP    19001889    £50.50    £46.20    £39.94
3.2i 24v V6 - Y32SE    55 AMP    19003129    £59.50    £54.45    £48.97
3.2i 24v V6 - Y32SE    70 AMP    9201470    £101.00    £92.43    £71.61
3.2i 24v V6 - Y32SE    50 AMP    93168488    £52.50    £47.25    £39.32
3.2i 24v V6 - Y32SE    65 AMP    93189923    £78.50    £71.84    £55.68
3.2i 24v V6 - Y32SE    85 AMP    93197903    £119.00    £107.10    £85.03
3.2i 24v V6 - Y32SE    60 AMP    93197905    £60.00    £54.00    £46.86
Bearings
3.2i 24v V6 - Y32SE    Front; With ABS; Hub Assy.    90486467    £141.00    £120.12    £106.29
3.2i 24v V6 - Y32SE    Rear; Wheel Bearing Kit    90486468    £52.50    £44.69    £34.67
3.2i 24v V6 - Y32SE    Front; Saloon; Wheel Bearing Kit; Ø 74mm    90510542    £45.40    £38.59    £30.12
Air Filters
3.2i 24v V6 - Y32SE    null    91149684    £18.05    £15.36    £11.19
Spark/Glow Plugs
3.2i 24v V6 - Y32SE    Ident FGR8KQE0    9195868    £5.10    £4.03    £2.96
Cabin Filters
3.2i 24v V6 - Y32SE    Carbon Air Combination Filter; (Ch.>) Y1000001; (>Ch.) X1999999    93165208    £20.55    £18.50    £15.08
3.2i 24v V6 - Y32SE    null    93182438    £9.85    £8.32    £7.08
Alternator Belts
3.2i 24v V6 - Y32SE    With Air Conditioning; Ident FD; 21.36 x 2020mm    93181720    £36.50    £31.03    £22.17
chrisgixer
« Reply #3 on: 02 February 2014, 23:27:36 »
Fuel Filters
3.2i 24v V6 - Y32SE    null    25313359    £10.70    £7.57    £7.55
OMEGA ('94-'03)
Shock Absorbers
3.2i 24v V6 - Y32SE    Saloon; Ident W2    72119084    £107.00    £90.98    £68.24
3.2i 24v V6 - Y32SE    Estate; With Automatic Self Levelling Device; Ident W7    72119085    £107.00    £90.98    £68.24
3.2i 24v V6 - Y32SE    Saloon; Except Sports Chassis; Ident WM    72119086    £60.50    £51.47    £35.92
3.2i 24v V6 - Y32SE    Saloon; Except Lowered Sports Chassis, Armoured Body; Without Automatic Suspension Levelling Device; Ident WB; (Ch.>) W1000001    90542942    £75.00    £63.78    £47.20
3.2i 24v V6 - Y32SE    Saloon; Without Automatic Suspension Levelling Device; Ident WB; (>Ch.) V1999999    90542942    £75.00    £63.78    £47.20
3.2i 24v V6 - Y32SE    Estate; Except Lowered Sports Chassis; Without Automatic Suspension Levelling Device; Ident WC; (Ch.>) R1000001    90542948    £75.00    £63.78    £47.20
3.2i 24v V6 - Y32SE    Left; Without Bad Road Package; Except Lowered Sports Chassis; Ident LP    9192291    £85.50    £72.71    £53.80
Oil Filters
3.2i 24v V6 - Y32SE    (Eng.>) 8300419    9192426    £5.25    £4.46    £3.41
3.2i 24v V6 - Y32SE    Timing Belt Kit; (Eng.>) 8300419; (>Eng.) 8578511    9201887    £144.00    £129.60    £116.87
3.2i 24v V6 - Y32SE    Timing Belt Kit; (Eng.>) 8578512    93172354    £149.00    £134.10    £118.15
Water Pumps
3.2i 24v V6 - Y32SE    null    93170697    £133.00    £95.35    £71.81
Wiper Blades, Front
3.2i 24v V6 - Y32SE    475; PS; Champion; 1x; Without Spoiler    93177182    £10.50    £8.40    £5.30
3.2i 24v V6 - Y32SE    475; PS; Champion; 1x; Without Spoiler    93195933    £9.20    £7.82    £5.73
3.2i 24v V6 - Y32SE    600S; DS; Champion; 1x; With Spoiler    93195937    £10.40    £8.84    £6.46
« Last Edit: 02 February 2014, 23:34:58 by chrisgixer »
chrisgixer
« Reply #4 on: 03 February 2014, 12:29:12 »
Useful post Chris, cheers, will need part numbers to quote at dealers new to me  :y
I've only done the 3.2. If others want to add their engine and associated parts. Or whatever they search, that would help further obviously.
I'll be there for a month of Sundays posting every omega model/engine/body shape.
I'm also assuming trade club don't mind. :-\
tigers_gonads
  • Kinston Upon Hull
  • Driving a Honda CR-V which doesn't smell of pee
    • Honda CR-V
« Reply #5 on: 03 February 2014, 14:39:26 »
Join Autobahn Stormers for 25 quid a year and get one for free  :y :y
chrisgixer
« Reply #6 on: 03 February 2014, 15:36:00 »
Chris, thanks for your hard work, much appreciated. I didn't understand your comment about alignment of items - won't a table format for display on here?
Also, is membership of Trade Club open to all or do you have to be a special person? If plebs are allowed to join, how do I do it?
Ron.
Here's the link from FAQ. Hopefully the links still work. :)
http://www.omegaowners.com/forum/index.php?topic=90491.0
Re they way copied text appears. This is the first item from above under shocks
Which should appear like this, but doesn't due to the length if descriptions etc
3.2i 24v V6-Y32SE  Saloon; Ident W2    72119084    £107.00    £90.98    £68.24
chrisgixer
« Reply #7 on: 03 February 2014, 15:46:07 »
Ron.
In all instances this is the line your interested in. Which appears in the order of Application, Description,PartNo. Etc etc. trade club price at the end is all you need to remember. That way people posting don't have to mess about with the spacing, just copy, paste, post.
If this works out as planned though, admin will need to tidy out all the non part no. related posts such as these, please start another thread in gen car chat if you have further questions to save them work later.
Please only post on this thread if you have trade club prices copied from the TC web site, or links where GM trade club parts are cheaper.
Hopefully as members use the TC site to search their specific parts for their model we will end up with a comprehensive library, and be able to get Genuine parts at the best price.
Thanks. :)
« Last Edit: 03 February 2014, 15:54:51 by chrisgixer »
chrisgixer
« Reply #8 on: 03 February 2014, 17:58:53 »
And the obvious one. Oil. Equates to 12.69 incl vat. Per 5 litre can. :)
OIL - 4 FOR THE PRICE OF 3
14/07/2012 | Special Offer
Our market-leading oil offer is exclusive to Trade Club members and continues until further notice.
It's a simple offer - every time you order four cans of the same specification oil, you only pay for three.
Offer available on 5-litre sizes of 10W-40 Semi synthetic and 5W-30 dexos2, the next generation in engine oil.
5W-30 dexos2
SM/CF A3/B4/C3
5-litre part number 93165557
Offer price for four cans £61.38
Equivalent to
£3.07/litre
SL/CF A3/B3/B4
5-litre part number 93165216
Offer price for four cans £40.23
Equivalent to
£2.01/litre
All prices exclude VAT. Prices valid from 3rd August 2012.
Back to Offers
« Last Edit: 03 February 2014, 18:00:27 by chrisgixer »
Keith ABS
  • Maldon Essex
« Reply #9 on: 03 February 2014, 19:06:34 »
  If this is construde as a thread hi jack, then please remove moderators.
On ABS, in the club shop, I have oil filters, both types, for the 2.5 TD for £4.50 each, genuine GM plus postage
Keith B
chrisgixer
« Reply #10 on: 10 February 2014, 20:30:05 »
Worth adding general part numbers to this?
Check strap bush, etc?
Page created in 0.538 seconds with 20 queries.
