Author Topic: 2004 VW Touran Diesel wont start, not lights on dashboard  (Read 16229 times)
steve6367
« on: 18 February 2014, 11:01:12 »
No lights on dashboard, car cranks over ok and fires for 1 second or so and then stops.
Not Omega, but the VW forums don't seem to have any thoughts so thought I would try here. If its not allowed then please delete :-)
Many thanks
Steve
andymp
  • Wakefield, UK
    • 2003 Omega CD 2.2 dti Est
Re: 2004 VW Touran Diesel wont start, not lights on dashboard
« Reply #1 on: 18 February 2014, 11:32:29 »
Fuel lift pump...?
Artificial intelligence is no match for natural stupidity...
steve6367
« Reply #2 on: 18 February 2014, 13:43:06 »
Good call, I will have a check. Slightly puzzled as to why non of the normal dash lights come on when switching ignition on though.
Steve
Ever Ready
  • Scotland
    • 2.2 CD Auto, Pug 308Hdi
« Reply #3 on: 18 February 2014, 17:13:20 »
Bit strange that you get no dash lights, although you can crank the engine over you may not be energising certain units that need to have power eg fuel pump as stated
An ounce of experience is worth more than a pound of enthusiasm.
steve6367
« Reply #4 on: 18 February 2014, 21:01:59 »
Gone though all fuses and relays tonight.
It does just seem there is no power to the Instrument Cluster as is seems totally dead. I believe on this car the  immobiliser is part of the cluster so I guess that could explain the failure to run.
No codes stored.
Giving up for tonight!
Steve
steve6367
« Reply #5 on: 18 February 2014, 21:05:31 »
Thank you TB :-)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #6 on: 18 February 2014, 21:09:12 »
No codes stored.
Steve
You could do with vagcom or similar being plugged and a global scan carried out,that should give you some idea as to what bits aren't working
other rides
  mk3 Volvo v70 2.0 Diesel ,Citroen C2, Pug 306 cabriolet
steve6367
« Reply #7 on: 18 February 2014, 21:20:55 »
I just tried downloading the free version, but it does not seem to recognise my Gendan EOBD interface unfortunately.
Maybe time to find someone who can :-)
Steve
hoofing it
« Reply #8 on: 18 February 2014, 21:44:01 »
Many thanks
Steve
Immobiliser problem here.
Does the key fob work ok
DrAndyB
  • Neston / Cheshire
    • 2.5 V6 CDX Manual (MFL)
« Reply #9 on: 18 February 2014, 21:52:29 »
Depends where you are, but if stuck then "unit 20 vw audi specialist" maybe worth a go. Based in Neston on the Wirral in Cheshire.  Everybody I know with VW's goes there, and has some nice RS6's and S8's  :D. Spookily I have a  VW Touran too!  But not a patch on my Omega V6  :y which i seek comfort from the great and the good on this tremendous forum  :y.
Good luck.
tidla
  • solihull
« Reply #10 on: 18 February 2014, 23:08:02 »
Engine number and mileage?
At a guess some of the engines have a shut off flap in the air intake manifold which fails to open due to carbon build up. push the flap arm to confirm. Gives the start for a second symptom.
« Reply #11 on: 18 February 2014, 23:34:18 »
Good luck.
Andy B, you have been trumped by a Dr........... :D :D :D
« Reply #12 on: 18 February 2014, 23:37:55 »
Good luck.
SWMBO has family around & they needed to be spoken to  ::) ::) ::) ;)
« Reply #13 on: 19 February 2014, 00:19:18 »
Good luck.
 :D :D ;)
henryd
  • west cornwall
« Reply #14 on: 19 February 2014, 00:23:42 »
Good call,they do indeed have that flap go faulty but doesn't explain lack of dash lights
other rides
Page created in 0.042 seconds with 20 queries.
