Author Topic: Starting troubles....  (Read 21990 times)
stuvaux
  • Stourbridge, West Midlands
    • 1999 Mig 2.5V6 CDX Estate
    • Dog Training HQ
« on: 06 March 2014, 15:12:05 »
Hi all
Over the past few weeks, my Omega (2.5 V6, LPG converted) has been a bit slow on starting. It then got worse a few days ago. I read codes, came up with 19, so replaced the crank sensor.
However, the problem is still there. I did forget to replace the vac pipe on the fuel pressure regulator, so thought that might be the problem. I replaced that, but still no joy. I am thinking it must be a fueling problem as the car runs fine on LPG (once I can get it started and switched over!)
Any ideas would be very much appreciated!
Thanks
Stu
Take a look at my Dog Training blog at Dog Training HQ
stuvaux
    • Dog Training HQ
Re: Starting troubles....
« Reply #1 on: 06 March 2014, 15:51:27 »
Forgot to mention, checked codes again and the 19 has now cleared
« Reply #2 on: 06 March 2014, 15:53:33 »
Do you mean the cranking is slow? Or it's normal but takes ages to fire?
stuvaux
    • Dog Training HQ
« Reply #3 on: 06 March 2014, 15:56:15 »
Sorry should have made that clearer! Turns over fine but taking ages to fire. It is definitely attempting to start. It will start sometimes, run for a few mins and then go lumpy and cut out. Runs fine on LPG
stuvaux
    • Dog Training HQ
« Reply #4 on: 06 March 2014, 19:36:16 »
Checked vacuum connections etc. Is there anything obvious I may be missing?
stuvaux
    • Dog Training HQ
« Reply #5 on: 06 March 2014, 20:27:22 »
I'm hoping the new crank sensor isn't faulty....surely if it was though it wouldn't run on LPG normally, and the fault code 19 would still come up?
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #6 on: 06 March 2014, 22:42:11 »
Code 19 sometimes does not show up, was the crank sensor an origanal gm part or copy(pattern)
if not gm thats your problem they are crap always by gen gm.
Jaguar XJ6
stuvaux
    • Dog Training HQ
« Reply #7 on: 06 March 2014, 23:03:04 »
It is a genuine GM one yes. But surely the poor running and stalling would still happen when running on LPG (which it doesn't)
« Reply #8 on: 06 March 2014, 23:14:56 »
When was the last time the fuel filter (petrol) was changed ???
stuvaux
    • Dog Training HQ
« Reply #9 on: 06 March 2014, 23:19:12 »
Now that is a good question - not recently  :-\
I was thinking that may be a possible culprit
« Reply #10 on: 06 March 2014, 23:46:14 »
Any fuel in it?
Sounds like a stupid question, but estates are prone to fuel starvation if left on a slope with less than a quarter tank.
If in doubt, put AT LEAST 2 gallons into it and report back :y
stuvaux
    • Dog Training HQ
« Reply #11 on: 06 March 2014, 23:52:33 »
Any fuel in it?
That is something else I had been thinking too. It should have some in there, the gauge is reading just under the 20 mark and the range is saying 87 miles! Still possible though. Will have to try it tomorrow
« Reply #12 on: 07 March 2014, 00:36:10 »
Not unknown for new GM crank sensors to be faulty ;)
stuvaux
    • Dog Training HQ
« Reply #13 on: 07 March 2014, 09:10:32 »
Surely it wouldn't run well on LPG if crank sensor was faulty....or am I wrong in thinking this?
« Reply #14 on: 07 March 2014, 10:23:39 »
Electrically the only difference between petrol and lpg is which injectors are working, so unlikely to be crank sensor, hence my fuel suggestion :y
Generally lpg is much more sensitive to weak or failing sensors than petrol, so I doubt it's a sensor issue :-\
Pages: [1] 2 3 4  All   Go Up
