Author Topic: Aircon HP valve replacment.  (Read 40378 times)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« on: 01 June 2014, 21:04:10 »
tools needed 17mm spanner, pair of neddle lock pliers. and one new valve p/no 13277003
 next place 17mm spanner on alloy nut..
then grip the valve body just above the spanner on the flats.
now hold the spanner and undo the valve using the lock pliers.
to refit the new one, smear the green o ring with some silicone grease(water pump grease), and tighten up.
new valve fitted.
« Last Edit: 18 June 2014, 10:10:40 by Jimbob »
Hoof'land storeman.
