Author Topic: Is it the starter motor?  (Read 6942 times)
Bigron
  • Witham, Essex
    • Omega 2.6 V6 Auto '51 Reg
« on: 08 June 2014, 17:39:53 »
Usually the first start of the day is perfect, but after a run, then leaving it for an hour or so, restarting has the starter cranking away for several seconds, as if the battery were low/flat, then it usually picks up and starts.
The battery is a few weeks old, so in good condition - checked by leaving headlight on for a long time and minimal drop in terminal voltage. I also thoroughly cleaned the battery terminals and connectors, with the exception of the lead to the starter itself, as I couldn't get near it.
Does this point to a failing starter motor, or does anyone have any other ideas, please?
Ron.
P.S. Are there any mobile mechanics near Witham, Essex, as I have other problems, too!
"When sorrows come, they come not single spies. But in battalions."
P.S. Any mobile mechanics near Witham, Essex, as I have other problems, too!
firemoth
  • Preston, Lancashire
    • Vauxhall omega 2.2dti est
Re: Is it the starter motor?
« Reply #1 on: 09 June 2014, 06:57:17 »
I've got the exact same issue and I suspect the same cause. What engine is yours? Mine is a 2.2dti
Bigron
  • Witham, Essex
« Reply #2 on: 09 June 2014, 08:50:40 »
2.6 V6 petrol saloon, '51 Reg.
firemoth
« Reply #3 on: 09 June 2014, 08:53:25 »
Also, if I start it from cold it's usually OK, but if I move it across the work car park for example (ie not far at all), knock it off while I wash it out something for a few minutes, it's them a bugger to start. Lots of white smoke when it does start from flooding itself
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #4 on: 09 June 2014, 12:31:00 »
Ron.
Might need to define this a bit more, Clicking, starter cranking over very slowly?
Check Battery volts, a good battery should read around 12.5 - 12.7 Volts with Ing. off (assuming fully charged).
Whats the battery volts doing when cranking over, ideally needs to be measured at the battery end and then at the Starter Motor end to see if you have voltage drop due to a bad connection (use some decent jump leads to the Volt meter at the starter end so you can see whats going on when cranking) measure both the above twice, once with the Neg (0v) of the Voltmeter on the Battery and then again with the Voltmeter Neg on an Earth Chassis point, and post up results.
Bigron
  • Witham, Essex
« Reply #5 on: 21 June 2014, 15:56:57 »
It might NOT be the starter motor!
The crimped connection at the positive battery terminal is getting quite hot, noticeable even when idling with no electrical loads on apart from just the engine.
I have cleaned the connectors, inspected the crimps and flexed them, but all LOOKS well enough. With the engine off, there is no current drain via the fat lead that disappears down towards the alternator/starter area, and only the expected current drain via the red lead to the fusible link when lights are turned on.
I am considering obtaining a positive battery clamp assembly from a scrappy and chopping/connecting my cables to it - does anyone have a car being broken at the moment (RobG)?
Ron.
« Reply #6 on: 21 June 2014, 16:08:37 »
None here Ron
Bigron
  • Witham, Essex
« Reply #7 on: 21 June 2014, 16:11:12 »
Thanks for looking, anyway, Rob.
I'm sure with all of the members here, somebody must have one - else it's off to the scrappy, if there is a Vx breaker locally........
Ron.
zirk
  • Epping Forest
« Reply #8 on: 21 June 2014, 20:04:05 »
You can buy battery terminals with a Clamp down bolt on to the Cable but they need to made up well, if that helps.  ;)
Bigron
  • Witham, Essex
« Reply #9 on: 21 June 2014, 21:21:47 »
Thanks, zirk. I've been looking on ebay but not too impressed - Omegas have a peculiar positive terminal arrangement!
I'm slightly confused about the nature of this problem: as outlined earlier, the terminal(s) get hot, but no drain to the alternator/starter cables - thinking again as I type this, I'm going to have to check again, as I don't believe myself....more to come, I guess!
Ron.
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #10 on: 21 June 2014, 22:15:43 »
Sorry Ron only just spotted this, I have the pos + lead still attached to my 2.2 breaker if they are the same length etc  :-\
zirk
  • Epping Forest
« Reply #11 on: 22 June 2014, 13:49:00 »
Ron, before you start ripping out and replacing your wiring, did you do the Voltage checks I suggested in my first post?
you can help prove the Starter wiring by using a decent Jump Cable between the Batt Pos and Starter Motor Connection and see if that aids in Starting.
Bigron
  • Witham, Essex
« Reply #12 on: 22 June 2014, 14:37:42 »
"zirk", all the voltage measurement confirm that I have a happy battery and charging system and I will try linking the starter directly to the battery as soon as I have a jump lead!
If it works, I think I'll bypass the original cable permanently - or check with "omegod" regarding price and carriage for his breaker assembly  (hint, hint....)?
I went tio a local boot sale this morning, plus some visits to various shops, and therefore needed to start the engine several times: when it was reluctant to start, keeping the ignition key engaged slowly brought the starter up to speed, and then the engine started.
On arriving home, I checked the terminal's temperature by hand and it was F. hot!
Ron.
zirk
  • Epping Forest
« Reply #13 on: 22 June 2014, 16:24:45 »
Ron.
Ok, cool, but the checks I suggested about measuring any Voltage drops in various places was to see if any leads or Earth return was breaking down or poor connections, ie, large Voltage drop across a direct point to point should indicate a suspect lead or connection.
Try the Jump lead to the Starter, i would only suspect the lead or Terminal to get hot whilst cranking over.
Bigron
  • Witham, Essex
« Reply #14 on: 22 June 2014, 18:25:43 »
I'm with you all the way, "zirk", but the odd thing in my view is the fact that the terminals at the battery clamp were that hot when I got home, at least 1/2 hour after the last engine crank.
The negative terminal and connections were all at ambient temperature, as you would expect.
Ron.
