Author Topic: meriva LH indicators all dead  (Read 2122 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 26 August 2014, 19:04:52 »
AU07 POF meriva manual petrol
My sister has brought her Meriva to me complaining that the LH indicators do not work. She is right. All 3 RH bulbs work, indicating left the dash flasher flashes fast, but none of the bulbs flash.
What could this be?
andyc
  • Norfolk
Re: meriva LH indicators all dead
« Reply #1 on: 26 August 2014, 19:48:43 »
Big yellow flasher unit has gone, common problem on the Meriva  & Corsa. Set you back about twenty quid
Andy
Thetford. Norfolk
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 26 August 2014, 19:50:34 »
Thanks. Where do I find it?
tidla
  • solihull
« Reply #3 on: 26 August 2014, 22:22:38 »
k11r =right hand relay
k11l = left hand relay.
if there the same, swap em around to confirm the fault.
located in the Engine compartment .
terry paget
    • 3 Astras 2 Vectra
« Reply #4 on: 27 August 2014, 08:05:16 »
Many thanks. Google threads suggest I may find the relay box under the scuttle, passenger side end, best to locate it by putting on flashers and listening.
terry paget
    • 3 Astras 2 Vectra
« Reply #5 on: 27 August 2014, 22:54:41 »
Thanks again for help. Today I bought the yellow relay from Vx, collected sister's car. Removed wiper blades and scuttle, then found relay box beneath windscreen passenger side, Could only find one big yellow relay, not two, but replaced it anyway. It cured the fault. Phew!
« Reply #6 on: 28 August 2014, 00:46:24 »
OOF strikes again............. :y :y
