Pages: [1] 2 3  All   Go Down
Author Topic: removing oil filter from a meriva 1.6  (Read 7022 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 02 December 2014, 19:04:45 »
My sister has asked me to service her Meriva 1.6. The oil filter (cartridge type) is very tight and I cannot shift it. Access is poor. Any tips?
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: removing oil filter from a meriva 1.6
« Reply #1 on: 02 December 2014, 19:07:06 »
Screw driver method  :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #2 on: 02 December 2014, 19:07:29 »
.....if you can get it in that is  :y
RIP Paul Lovejoy
« Reply #3 on: 02 December 2014, 19:07:47 »
cartridge type .........  ::) ::)
Webby the Bear
  • Northampton
« Reply #4 on: 02 December 2014, 19:10:26 »
Oh. I thought the metal ones were called cartridge filters and the other ones were ''paper'' filters.
Sorry. i'll shut up go away  ::)
RIP Paul Lovejoy
« Reply #5 on: 02 December 2014, 19:11:49 »
I'd say that a paper & cartridge were the same thing as opposed to a cannister type  ;)
Webby the Bear
  • Northampton
« Reply #6 on: 02 December 2014, 19:12:52 »
arr...getting canister and cartridge mixed up.
exits stage left  ::) ;D
RIP Paul Lovejoy
« Reply #7 on: 02 December 2014, 19:17:26 »
 ;D ;D don't forget to take your screwdriver with you  ;)
Webby the Bear
  • Northampton
« Reply #8 on: 02 December 2014, 19:18:00 »
Got a good place for it  :-[ :-[ :-[ ;D ;D ;D ;D
RIP Paul Lovejoy
Webby the Bear
  • Northampton
« Reply #9 on: 02 December 2014, 19:18:51 »
Ps, again sorry Terry.
Please. Proceed as normal...  ::)
RIP Paul Lovejoy
« Reply #10 on: 02 December 2014, 19:23:39 »
24mm socket iirc :-\ a couple of extensions and a breaker bar :-\ should simply undo...
terry paget
    • 3 Astras 2 Vectra
« Reply #11 on: 02 December 2014, 19:45:55 »
Woops! It's canister type, in fact same part as on some Omegas. It may well be a screwdriver job - I presume you mean shove a screwdriver through it, Webby. I've spent an hour trying to get hold of it with a chain device, also a belt tool. Do you mean hammer a long sharp screwdriver through it and use it as a lever, Webby?
« Reply #12 on: 02 December 2014, 19:48:27 »
Used a gloved hand, but watch yourself on the Cat :y
Tap a long screwdriver in to it  from the two o'clock position and drive it home, the simply pull the screwdriver up and over anticlockwise...
Then unscrew by hand :y
« Last Edit: 02 December 2014, 19:51:00 by Taxi Al »
  • Online Online
« Reply #13 on: 02 December 2014, 20:44:14 »
That's the theory. :D ;)
« Reply #14 on: 02 December 2014, 21:08:10 »
Woops! It's canister type,  .....
turns out you were right Webby!  ;D ;D ;D
Pages: [1] 2 3  All   Go Up
