Author Topic: Unexplained engine cut-out  (Read 3739 times)
LostBloke
  • nth somerset
    • 2001 omega elite auto 2.6
« on: 12 December 2014, 19:35:09 »
After driving about 45 mins, just nearing home, I let a car out of my side street and the engine died. the battery, oil and engine lights came on, all the electrics were working (the lights were on and the heater was blowing). the started span the engine but no sign of life. After a fair old curse I pushed the car to a safe spot and, out of interest, tried again and it started immediately. I drove it the 100 yards or so to my parking space, parked, and as I reached to switch it off, it stopped again. The temperature gauge showed normal, the petrol tank was nearly full and the engine did not seem/smell hot. So, a) Please, any ideas of a possible fault? and, b) I have a cheapo fault reader, where is the OBD socket situated? Thanks for any help
Regards
Re: Unexplained engine cut-out
« Reply #1 on: 12 December 2014, 19:53:06 »
Crank sensor. If it`s a 2.5/3.0 use a paperclip for codes. If a 2.6/3.2 do the pedal trick
http://www.omegaowners.com/forum/index.php?topic=90581.0
OBD socket is under fusebox cover in cabin
« Last Edit: 12 December 2014, 19:55:16 by RobG »
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #2 on: 12 December 2014, 20:04:33 »
yep robg has it spot on, crank sensor. GENUINE GM PART ONLY.
Gary.
Jaguar XJ6
LostBloke
  • nth somerset
« Reply #3 on: 12 December 2014, 20:48:45 »
Thanks for the replies, I'll test it in the morning. As a point of interest, what price a sensor and are they hard to fit?
Regards
« Reply #4 on: 12 December 2014, 20:58:22 »
2.6/3.2 are circa £70... Only buy from a physical Gm dealer. Buy on line or cheap at your peril.
Doddle to fit as per the guide
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #5 on: 12 December 2014, 22:21:58 »
...and even they can sometimes be dodgy, see other recent posts. :y
chrisgixer
« Reply #6 on: 12 December 2014, 23:03:18 »
2001 would be drive by wire so pedal trick. Looking for 0335 crank sensor code. Which, among other possible codes, would be;
10 flashes.
3 flashes.
3 flashes.
5 flashes.
...for the uninitiated. Confirm with a code reader if you wish but generic obd2 readers can be unreliable it what codes they see. Pedal trick doesn't lie :y
« Reply #7 on: 13 December 2014, 03:28:29 »
True enough of most things, but if a dealer supplies a duff genuine part then you have some recourse... Buy cheap pattern shyte of eBay, you're lucky to get a receipt, let alone a guarantee ::)
Shackeng
  • Ramsbury
« Reply #8 on: 13 December 2014, 09:36:33 »
Quite right Al, I was really trying to make the point that, as discovered by others, even fitting a GM sensor may not cure the problem, which may still turn out to be another duff sensor. Hence always listen to advice given on OOF regarding codes etc. :y :y :y
chrisgixer
« Reply #9 on: 13 December 2014, 13:15:23 »
Was there not a question over vipers sensor being correct for the car though?
But yes most manufacturers have a failure rate. No matter what's being made.
But add in cheap Chinese shite made for tuppence and an even bigger mark up than oe, then you see where the quality goes. Such as it is. New sensors do fail.
Just hope my new spare is ok in the boot after being rattled around in the box for the last 40k odd miles.
« Reply #10 on: 13 December 2014, 13:25:07 »
Mine is safely tucked up in the garage... the AA can drag the car home if it goes ;D
chrisgixer
« Reply #11 on: 13 December 2014, 14:50:54 »
Your missing a trick there I rekon. Get the AA to fit it. What are we paying them for after all? ;D
yt03
« Reply #12 on: 13 December 2014, 15:12:55 »
Sorry posted on wrong topic and won't let me delete my post!!
« Last Edit: 13 December 2014, 15:20:23 by yt03 »
« Reply #13 on: 13 December 2014, 17:23:35 »
Fair point, but does depend how far they have to drag it ::)
« Reply #14 on: 13 December 2014, 17:33:27 »
I too would be suspecting crank sensor, but see what codes are stored (paperclip (2.5/3.0) or pedal trick (2.6/3.2))
Page created in 0.024 seconds with 20 queries.
