Author Topic: drakos, omega trackday toy  (Read 18791 times)
drakos
  • netherlands
    • calibra,omega,
Re: drakos, omega trackday toy
« Reply #30 on: 07 January 2016, 18:20:37 »
sorry, not the promised update, not enough time today to start with the coilover.
in the hour i've spend in the garage i took a angle grinder and removed al the mounting bolts for the heatshields (most where broken anyway and exhaust routing will be drastically different, more on that later  ;) )
after that took the wire brush on the grinder and removed all the rust from the bottom and cleaned up the driveshaft
al the rust was superficial and nothing needs repairing  8) amazingly clean for a 94 opel/vauxhall  :o
calibra v6 3.0 4x4
omega v6 2.5 trackday project
calibra 8v daily
drakos
  • netherlands
    • calibra,omega,
« Reply #31 on: 08 January 2016, 20:33:21 »
gave the front half of the car a few layers of stonechip paint and sprayed the tunnel white just like the engine bay. this way it is easy to see if something leaks and where it is comming from  8)
next is to stonechip the rear and mask off the white to paint the overspray black again
calibra v6 3.0 4x4
calibra 8v daily
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #32 on: 20 January 2016, 11:36:00 »
Looks beautiful, shame to get it dirty  :)
 Please let us know what stonechip paint you use. I've used some stuff (tetrasyl, if I remember right) but I'd like to invest in some of the 'rubber' stuff that replicates the original underseal better, but yet to make a purchase. .
Ever Ready
  • Scotland
    • 2.2 CD Auto, Pug 308Hdi
« Reply #33 on: 20 January 2016, 19:26:10 »
Keep up the good work, I do like to follow a project
An ounce of experience is worth more than a pound of enthusiasm.
drakos
  • netherlands
    • calibra,omega,
« Reply #34 on: 24 January 2016, 17:27:47 »
thanks,
the stonechip is nothing special, just cheap motip/duplicolor overpaintable stonechip.. wouldn't recommend it for normal use except for trailing arms and stuff..
in my case it is just to give it a uniform color, cover the bare metal from the rust removal and a little bit of protection without being sticky (and heavy) like real undercoat.
on my other cars i use caprotec rx5 and rx10.. eats rust (rx5) and the second layer is real undercoat (rx10) it is available in all colors and gives a nice silk gloss finish and feels a bit like rubber. not a mark or rust on my car after 10 years of abuse and rain  8)
calibra v6 3.0 4x4
calibra 8v daily
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« Reply #35 on: 25 January 2016, 12:08:54 »
Calibra town!  ;D
PM with your requests.
drakos
  • netherlands
    • calibra,omega,
« Reply #36 on: 25 January 2016, 14:40:14 »
That is actually only half the calibra collection  :P
Got myself a 100% stock 8v, a v6 4x4 show/track car and a rear half that funtions as a event trailer  8)
The one in front of the omega is from a mate. In the progress of being converted to rwd.
calibra v6 3.0 4x4
calibra 8v daily
« Reply #37 on: 25 January 2016, 15:01:54 »
Thanks for the info  :y
RWD calibra? Great idea! Would you be using the 4wd rear axles, or is that a surprise for another day? Very interested to hear how you'll be doing it  :)
humbucker
  • Cambridgeshire
« Reply #38 on: 25 January 2016, 17:26:07 »
A fellow Cavalier Turbo owner has achieved the same using Sapphire Cosworth running gear.
drakos
  • netherlands
    • calibra,omega,
« Reply #39 on: 25 January 2016, 17:47:33 »
Simple way would be to use a omega 3000 diff and 2.4 rear axles..plug and play
 but we could not find any so stripped down a omega b and using that rear diff,shortened drifeshaft and axles.. gearbox also omega b.. engine is a saab turbo with a big garret with fmic
calibra v6 3.0 4x4
calibra 8v daily
« Reply #40 on: 26 January 2016, 11:58:07 »
Fascinating! Hearing that makes me wonder why didn't they make the Calibra rwd all along? I'm sure that would alter the handling characteristics nothing put positively. It never quite got rid of its Cavalier underpinnings, maybe the dashboard was too obvious for many people, kind of 'sheep in wolf's clothing' thing. Which is a shame, because I never thought so and always thought 'oh it#s a cav underneath...and? what's wrong with that? Cav Mk IIIs were brilliant cars!' but certainly with another few quid spent the if all Calibras were rwd maybe people would have felt they were buying a 'very cheap baby 3 dr Senator', as opposed to an 'expensive 3 dr cavalier'
Also Frod running gear in a Vauxhall is just wrong, sorry!!  :D But a beautiful pic, and lots of effort and skill there.  :y
drakos
  • netherlands
    • calibra,omega,
« Reply #41 on: 02 February 2016, 19:40:53 »
quite a lot done the last weeks.
first was to customize the wiring loom, no pics when finished but believe me, it is light  ;)
lost everything that wasn't necessary, the entire loom now fits in a grocery bag
the list what remained is shorter.
-all light stil work, but ditched the broken light module, and all other wiring.. all that remains are a few direct wires for the new switches in the center ( fuses gonna move to the center console to).
-merged the left and right light units, so no more separate wires or fuses.(for example, only one wire to the 4 rear lights and licence plate, one wire for the left and right main beam.. etc)
-blinker and hazard lights all still work
-wipers and window washer still work except the interval, also removed the washer level warning
-dash still works, only removed the wires and bulbs that weren't used anymore
-no more ignition barrel, everything is nog a switched positive ( killswitch is the new key  8) )
-immobilizer is still there, glued the chip to the ring
-positive feed wire moved to the inside of the car
- only one off the 2 horns remained
and that is literally all that remained  8)
lost the servotronic, all fan and cooling wires/relays ( only a positive feed for the new fan relay remained).. abs, airco,tc and off course everting that was for the inside..
because i lost the abs, i also lost the speed signal. acquired a vss relay from a corsa to get a speed signal direct from one abs sensor. and gonna build a signal converter to deal with the difference in abs teeth and for fine tuning the speedo.
enough text and time for pics,
got a spacer for the gearbox made to account for the loss of the dual mass flywheel;
after that everything came together without any problems and a few hours later the engine was in  8)
and the dash in for now, ordered some carbon plates to fill the gaps and gonna use the center hole for the new switches,killswitch,start button and a few fuses
and cleaned up the rear diff and removed the abs rings
calibra v6 3.0 4x4
calibra 8v daily
« Reply #42 on: 03 February 2016, 09:57:49 »
Cannot wait to see what this weighs with all the modern 'junk' (subjective) removed. Very nice idea about minimising the loom, I wouldn't have thought about that. Purely on an economy point of view, what would happen if you took maybe 200kg off the weigh of an Omega, that's before any actual performance mods occur. Lotus 'added lightness' methodology.
Keep it coming, fantastic project!  :)
Bojan
  • Croatia, Slavonski Brod
    • MV6 3.0
« Reply #43 on: 04 February 2016, 06:28:11 »
Great stuff here, it's really rare to see fully and properly stripped omega.
Do you perhaps know how much discarded loom weigh?
Also, I can imagine how much space is gained in small spaces (like behind the dash) now when there is no thick loom branches.
Diff -  is it a standard, open type or LSD?
PS. A little OT – that off-road van (mitsubishi?) on several images looks very interesting (with A/T tyres, sand channels, snorkel...).
drakos
  • netherlands
    • calibra,omega,
« Reply #44 on: 04 February 2016, 11:37:56 »
no idea how much weight is lost at the loom.. but it is a lot.. 3 trashbags of wiring gone and that is not including the weight of all te relays, sensors, brackets, switches etc.. think that 30kg is a minimal guess  8) and then another 30kg from control units,horn,blowers etc.
will do a weighting soon when it is complete and running but before the cage goes in
diff is stock for now, looking for a lsd but that is not on top of my priority list now..
fuelbag,swirlpot, big brakes etc are more important as upgrades after the initial build to get it driveable
the mitsubishi is a great car.. it is a l200 (i think?) 4x4 "oem".. lifted,dual fueltank, snorkel etc.. inside is more like a campervan.. is from a mate of mine that uses it properly in the sahara and all kind of rugged places.. at the moment it is on transport to south amerika for a vacation/expedition  8)
calibra v6 3.0 4x4
calibra 8v daily
Pages: 1 2 [3] 4  All   Go Up
Page created in 0.04 seconds with 21 queries.
