Author Topic: Slightly rough idle after cambelt change  (Read 7318 times)
berserkerboy
  • Llansadwrn, Carmarthenshire SA19
    • 3.2 V6 Elite 02 LPG
« on: 31 January 2016, 14:28:02 »
Bit disappointed after everything seemed to be going so well.
Belt changed. Everything spot on. Torqued up and tensioner set as per DVD ie. marker set for new belt.
Engine turned over several times to ensure timing marks spot on.
Found a vacuum pipe split going to bagpipes, repaired.
Unfortunately though, I have noticed the above problem. Sitting in the car I can feel it wobble slightly. Just wondering if I should dissemble again and check that the timing hasn't moved. Don't see why it should have.
Also have a new noise when running on petrol which disappears when I switch over to LPG. A kind of dull ticking noise.
Anyone any suggestions?
minifreek
  • Wigan
    • 2.4 V70 & 94 Mini SPi
Re: Slightly rough idle after cambelt change
« Reply #1 on: 31 January 2016, 15:05:08 »
Dunno about the LPG problem but sounds like injector noise...? but probably not as they switch off when on LPG...?
Anyhoo, check the belt timing, could be out by a tooth, don't rely on the markers on the belt to be 100% accurate...
BTW, have you changed cams too or just belt...?
D.I.L.L.I.G.A.F...
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #2 on: 31 January 2016, 15:06:13 »
Air leak perhaps, were the 6 large o-rings under the  plenum ok?
berserkerboy
« Reply #3 on: 31 January 2016, 15:15:45 »
Belt, tensioner and rollers. Gates kit. Used a sykes pickavant timing tool so not relying on belt markings.
minifreek
  • Wigan
« Reply #4 on: 31 January 2016, 15:16:10 »
Would possibly hear the air being sucked in maybe...?
but good call... :y
D.I.L.L.I.G.A.F...
berserkerboy
« Reply #5 on: 31 January 2016, 15:17:52 »
I suppose they looked a bit flat.
  • Auckland
    • Mazda MPV
« Reply #6 on: 31 January 2016, 15:34:38 »
When did you last change the spark plugs?
It sounds as though you have an intermittent misfire if the cam timing is spot-on as described.
berserkerboy
« Reply #7 on: 31 January 2016, 15:42:39 »
Plugs about 4k ago. Didn't have this issue before belt change.
berserkerboy
« Reply #8 on: 31 January 2016, 15:52:15 »
Gonna take it all apart again to check that timing is still as it should be. Hopefully be quicker now that I've done it so recently.
I'm suspecting the air leak if timing is as should be.
If I need new seals does anyone know the part number or better still the best place to order them from? 3.2 year 2002.
Alternatively, can I refurb them by coating in silicon grease. I've heard this will make them swell a bit?
« Reply #9 on: 31 January 2016, 18:52:03 »
Yes, check for air leaks :y
K_V6
  • Spain
    • Omega y22dth/Vectra let
« Reply #10 on: 31 January 2016, 19:46:39 »
If before well fine, I would check the the times of camshafts again.
Sometimes one tooth makes fail on idle
From Spain. Sorry for my English
berserkerboy
« Reply #11 on: 31 January 2016, 22:34:15 »
Uh oh!
Well, glad I checked again as something has happened.
Firstly, I noticed that the tensioner position has moved. It is now lined up with the marker for an old belt. So does that mean it has tightened itself?
Secondly, I have noticed that there is more than one timing mark on cams 1 and 2. There is a mark in the middle of a tooth and therefore quite a long mark, I'll call that mark L. There is also mark which is between a tooth and therefore quite short, I'll call that mark S. So 2 marks on each cam separated by about 6 teeth.
On my car the timing tool shows that S on cam 1 and L on cam 2 is lined up. This must have been the setup before I changed the belt as I can't believe that 1 has jumped about 6 teeth.
Cams 3 and 4 only have 1 timing mark and line up.
So to summarize, I've got timing marks lining up perfectly but I'm not sure now whether they are the right ones lining up. :(
« Reply #12 on: 31 January 2016, 23:26:24 »
Uh oh!
Can you take a picture? :y
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #13 on: 31 January 2016, 23:51:22 »
Each cam number should line up with its respective cam. Cams 1 and 2 are straightforward enough but cams 3 and 4 should line up as shown below.
Cam 3 shows the left notch as 3 so line cam 3 to the left notch and cam 4 shows the 4 as the right hand notch so cam 4 should be lined up with the right hand notch.
The last photo is to show cam 4 clearer. I would feed the belt as I said in your other thread.  :y
Hope that helps.
berserkerboy
« Reply #14 on: 01 February 2016, 06:54:10 »
OMG! Thank you YZ250. Everything is as it should be then. You don't know what a relief that is. After doing everything by the book I thought I had majorly screwed up! Spent the evening fretting about it. You can see why the extra marks could lead to confusion, for a novice, but this explanation makes it all clear.
Don't know why the tensioner has moved. I thought I had torqued it up properly but you never know. Will set back to the new belt position or do you think I should leave as is, a few mm before the old belt mark, and retorque?
Thanks once again.
