Author Topic: Noisy old Merc.  (Read 1888 times)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
Noisy old Merc.
« on: 12 March 2016, 10:44:22 »
At the MOT station last week with my old 2.5D, I started the engine after the test was finished and the throttle stuck open. It revved its nuts off for a few seconds before I switched it off. Discovered the linkage had got caught on something so sorted it there and then.
Problem is, ever since then, at idle it sounds like an old black cab that hasn't been serviced for a long time. At higher revs at doesn't sound so bad, but still a bit knocky.
Noise is definitely from the top end,so Im thinking valvegear related ?
It still performs the same as it did previously, so presumably not bent valves or similar. Knackered lifter maybe ? :-\
Sorry, posted in wrong section. Thought I was in gen car chat. Hopefully a kind admin will move.  :-[
« Last Edit: 12 March 2016, 10:46:27 by Migv6 »
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Noisy old Merc.
« Reply #1 on: 12 March 2016, 11:42:25 »
Will the shitty oil and revving the balls off it, you might have displaced some crap in the sump which is now restricting oil flow.
Drop the sump and clean it and the strainer out.
Give it a few short (500 ish mile) oil changes with cheap crap and see how it is  :y
Re: Noisy old Merc.
« Reply #2 on: 12 March 2016, 14:58:35 »
Don't they Rev the 'dangle berries' off it (4000rpm) to do a smoke test for the MOT?
Migv6 le Frog Fan
Re: Noisy old Merc.
« Reply #3 on: 12 March 2016, 16:02:53 »
Something like that yeh. It was ok after that. Problem only appeared after the stuck throttle episode. Ive just had the cam cover off and all looks fine. Used a length of wood to listen and it sounds like it could be from an injector on pot 4 or 5.
Its not that bad tbh.Im just concerned that as it happened after the throttle sticking open, this has caused some kind of problem.  :-\
