Author Topic: 2.2 cam sensor problem  (Read 5293 times)
Andy86787
  • Hull
    • Omega 2.2CD
« on: 13 April 2016, 15:35:26 »
Hi, hope somebody can help me with this issue. I had what appears to be a fairly common issue with my 2002 2.2 petrol, the engine light (one with spanner) would come on intermittently whilst driving but would not effect performance at all. It would then go off and come back as and when. Reading through the posts on here it seems that this was most likely a cam sensor problem, so I decided to replace and bought a pattern part off a Vauxhall specialist website. After I had replaced the cam sensor the engine was difficult to start and kept cutting out, I then read that people insist on a genuine Vauxhall part (Siemens one). I therefore repeated the process and put the old sensor back in and now the engine runs fine once more but the engine light is on permanently. Is this now simply a case of ordering a replacement Siemens unit and the fault should be fixed?
Thanks
Re: 2.2 cam sensor problem
« Reply #1 on: 13 April 2016, 15:53:11 »
Might need fault codes cleared, get new sensor and go from there  :y
Andy86787
  • Hull
    • Omega 2.2CD
« Reply #2 on: 13 April 2016, 16:03:04 »
Yeah that was my thoughts, does anyone know where I can get a genuine part from? Thanks again
« Reply #3 on: 13 April 2016, 16:11:48 »
Vauxhall Dealer  :y
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #4 on: 13 April 2016, 16:18:53 »
Although its said many times on here that the pedal trick doesn't work on the 2.2,
I saw a post here a couple of months ago saying it does if you put the car in "D"
Must get hold of my old 2.2 to have a go  :-\
« Reply #5 on: 13 April 2016, 16:30:19 »
Humm, I've never tried pedal trick with my 2.2 manual in gear, might give it a try.
Steve B
  • Leicestershire
« Reply #6 on: 13 April 2016, 16:34:17 »
There was a newish member on here and he was told pedal trick dont work on 2.2
And his reply was " yes it does if you put the car in "D"...
Andy86787
  • Hull
    • Omega 2.2CD
« Reply #7 on: 13 April 2016, 16:39:41 »
What is the pedal trick?
Andy86787
  • Hull
    • Omega 2.2CD
« Reply #9 on: 13 April 2016, 16:47:44 »
Just done the pedal trick got code 1555 any ideas???
Andy86787
  • Hull
    • Omega 2.2CD
« Reply #10 on: 13 April 2016, 17:08:12 »
So code p1555 is throttle position Sensor and nothing to do with cam sensor as originally thought. Is this an easy fix?
Steve B
  • Leicestershire
« Reply #11 on: 13 April 2016, 17:17:31 »
clean breathers and throttle body. Check for air and vac leaks.
http://www.omegaowners.com/forum/index.php?topic=90528.0
Steve B
  • Leicestershire
« Reply #12 on: 13 April 2016, 17:23:41 »
So the pedal trick worked. Was that In "D"  ?  ..Go on get out there again and do it in "P" Then tell us the result  :y
Andy86787
  • Hull
    • Omega 2.2CD
« Reply #13 on: 13 April 2016, 17:25:28 »
First I tried it in P and it didn't work so put it into D and hey presto it worked a treat. Mine is a 2002 2.2cd
Steve B
  • Leicestershire
« Reply #14 on: 13 April 2016, 17:31:55 »
Magic  :y You need to claen breathers and Throttle body next...Dead easy  :y Follow that guide
