Author Topic: Rear subframe rear bushings  (Read 16268 times)
mandula
  • Finland
    • Opel Omega -03, Z22XE man
« on: 10 June 2016, 18:52:46 »
I found out that my rear subframe rear bushings were teared up and could not find any replacements, so I decided to make them by my-self.
Here's some pictures of new ones, I used Powerflex 99-112 PU-bushigns (95 SHa) and made mountings for them. There was some R&D during manufacturing process so finished items are a bit different than on drawing.
Haven't mount them yet, will do it tomorrow and post some feedback how they work.
Dimensions for mounts
Powerflex 99-112 bushing dimensions
Old ones
Parts, I didn't use that lower plate because mount felt strong enough anyhow
Finished
Waiting for paint to dry..
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Rear subframe rear bushings
« Reply #1 on: 10 June 2016, 19:02:45 »
Nice. Could you have machined the centre from one piece and saved a bunch of welding?
And I'm going to borrow your dimensions and apply them to the rough jig I modeled for casting urethane into an old mount
mandula
  • Finland
« Reply #2 on: 10 June 2016, 19:07:11 »
It was very fast assembly like that, but of course it would be better and more pro from one piece to center ;) I don't have machines to do that, dunno how much that would cost to order.. Steel was like couple of euros and set of two bushings about 35-40 euros.
mandula
  • Finland
« Reply #3 on: 11 June 2016, 09:29:41 »
Correction on dimensions: bolt holes (to car chassis) distance between each other is 115 mm, not 120 mm.
Almost got them installed, just needs to machine bolt holes to correct dimensions.
mandula
  • Finland
« Reply #4 on: 11 June 2016, 10:35:01 »
Done installing, was pretty easy job after all..
To drop rear subframe from rear:
- Lift rear on stands and remove rear wheels
- Remove rear shocks from bottom
- Remove locking bottom clips of brake flex hose and take out from holders
- Remove ABS sensor connectors from holders above rear bushings
- Remove two holder rubbers from end of exhaust pipe and one rubber near rear arch
- Put something between exhaust pipe end and bumber to hold exhaust pipe as low as possible
- Put jack under dif to hold it on place
- Remove rear bushing bolts and release jack to drop subframe
- Using steel bar or board to force subframe low as possible and lock it there
- Now you can see rear bushing bolts to subframe and remove them
Some pics of new bushings in place:
I hope this helps if somebody wants to also upgrade those bushings.
Instantly noticed better handling when cornering, no more feeling that rear is moving sideways.
Also resonation disappeared when using motor to slow down, usually happened when slowing down from 90 to 80 km/h.
Will go to MOT late this month, I hope they like this modification also  :)
  • Chatham, Kent
« Reply #5 on: 11 June 2016, 10:40:26 »
Looks good to me. It shows what is achievable with some thought and simple techniques.
« Reply #6 on: 12 June 2016, 12:16:52 »
Also may be worth those who can't fabricate them having a word with Serek, as he was looking to import various poly fixings, he may be able to get diff mounts.
I know he was already looking at the larger subframe bushes (proper Omega ones, as opposed to the Monaro ones a few of us have), wishbone ones etc...
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #7 on: 12 June 2016, 12:34:33 »
Does putting it up on the forum infringe any copyrights? Just asking. ???
« Reply #8 on: 12 June 2016, 16:26:29 »
Shouldn't as this is clearly a diy fabrication and isn't being passed off as anything else  ;)
mandula
  • Finland
« Reply #9 on: 12 June 2016, 16:38:05 »
Im not patented this (yet ;) ) so I think it is okay to share this. And this aint exact copy of the original bushing there is no copyrights broken (I doubt there is any anyway).
« Reply #10 on: 12 June 2016, 17:12:16 »
It was a dig at a comment I made on another thread about summat being passed of as a genuine item. Which this clearly isn't  :y
« Reply #11 on: 12 June 2016, 17:56:06 »
And a prime example of how this forum has gone downhill over the years... ::)
ronnyd
« Reply #12 on: 14 June 2016, 11:00:25 »
My original post was regarding the Powerflex drg.(PDF) which has a copywrite at the bottom. Just asking a question really as i have no idea. :y
mandula
  • Finland
« Reply #13 on: 14 June 2016, 11:11:03 »
Oh, that is found from www.powerflex.co.uk/i/product_images/99-112%20WEB.pdf, so it is freely available. And I think that copyright is just for preventing copying/reproducing the bushing it-self, correct me if I'm wrong.
ronnyd
« Reply #14 on: 14 June 2016, 11:20:16 »
Thanks for that mandula.  :y
