Author Topic: Cleaning gear selector switch - grease?  (Read 5673 times)
steve6367
« on: 01 August 2016, 20:18:20 »
So my lights were doing strange things, I've popped it off and cleaned with contact cleaner. All looks good now, before I started it was all smothered in grease. Should I put some back? What type?
Steve
« Last Edit: 01 August 2016, 20:30:43 by steve6367 »
Re: Cleaning gear selector switch - grease?
« Reply #1 on: 01 August 2016, 20:42:03 »
I'd put silicone grease back in
frostbite
  • Roanapur City aka Skem
    • 00' e46 325i se
« Reply #2 on: 02 August 2016, 10:00:19 »
+1 I cleaned mine out and never repacked it. I have since noticed the ac leaks on it or very close to it so a job that needs doing
Im going to maplin for dielectic grease
e46 325i se - 1.8vvti avensis liftback
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #3 on: 02 August 2016, 10:06:25 »
Is vaseline/petroleum jelly as good/substitute?
steve6367
« Reply #4 on: 02 August 2016, 10:58:04 »
Thank you all, I used a small amount of Keenol as its what I has at 8pm in the rain when I realised the car was stopping my closing the garage door  :-[
It's not fixed the problem, but if it stops raining today I will check the adjustment again.
If not its new switch time I guess, are they VX only?
« Reply #5 on: 02 August 2016, 11:06:48 »
Surely a known good one is perfectly fine. There's any number of AR25s in people's back yards, having been replaced for AR35s... all perfectly serviceable, no doubt? Can imagine a new switch being a fair few pennies
steve6367
« Reply #6 on: 02 August 2016, 23:01:11 »
So cleaning the selector made it worse, so I thought I know I'll pull the one off the 2.2 which is currently off the road. That does not work either, did so fine when tested before removal.
Any thoughts? I shall pop the original from the 2.5 into the 2.2 AM to see east happens, but I'm meant to be driving to Exmore tomorrow.
3 Omegas and not one actually bloody working!
Any thoughts really appreciated  :y
steve6367
« Reply #7 on: 03 August 2016, 08:31:33 »
Photo of inside the unit removed from the 2.5:
https://www.dropbox.com/s/td1hp97gys4zo1d/2016-08-02%2022.35.11.jpg?dl=0
steve6367
« Reply #8 on: 03 August 2016, 09:46:56 »
All ok this morning in every position when cold, drive around the block and other than D & N all the other positions switch all of the lights on.
Can the box itself cause these issues? Or ECU? Or does it have to be the selector switch?
« Last Edit: 03 August 2016, 09:54:03 by steve6367 »
frostbite
    • 00' e46 325i se
« Reply #9 on: 03 August 2016, 10:57:56 »
Try and run it with no grease in at all also try and use an electrical contact cleaner
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #10 on: 03 August 2016, 21:03:36 »
There's a guide in the relevant section. Use silicone grease from Maplin, or as it use to be called switch grease.
Hoof'land storeman.
