Pages: 1 ... 5 6 7 8 9 10 11 [12]   Go Down
Author Topic: Senator A2.  (Read 9730 times)
neil74
  • newport
    • 2.6 elite estate.
Re: Senator A2.
« Reply #165 on: 14 November 2017, 21:19:04 »
Reminds me of my white 2.5 manual senator. when started from cold it would cut out immediately until it warmed up. also the handbrake barely worked on one side and it was always fun to try to start the car from cold on a hill. I was nagged into selling it by my sisters current boyfriend at the time and to top it off he had already borrowed my previous black 3.0 one and managed to tear the seat back and stuff one of the rear doors in.
Steve Brookman
  • Blackwood, Gwent
    • Royale/Senator
Re: Senator A2.
« Reply #166 on: 30 May 2018, 20:23:40 »
Another MOT passed today!
Previous
Omega 2.5 GLS Auto Estate         S115 JVV
Omega 3.0 Elite  Auto Estate        T639 TFA
Steve Brookman
  • Blackwood, Gwent
    • Royale/Senator
Re: Senator A2.
« Reply #167 on: 28 July 2018, 10:32:00 »
Update.
Senator and Royale used daily in rotation. Both going well-had an issue with the Royale cutting out-but a second hand ECU that I had in the garage cured this. Sold my Range Rover-only did 800 miles in one year-so Senator and Royale will be used more.
Royale's MOT is up in a month and it may need a bit of welding to the ends of the sills.
Love driving both cars-gets lots of looks and comments-both easily keep up with traffic and the Senator in particular is supremely comfortable. Only downside is that they both like a drink!
Steve
Previous
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
Re: Senator A2.
« Reply #168 on: 28 July 2018, 15:16:52 »
Hi Steve. Great to hear both cars are up and running well.
Hope I'm not the bringer of doom here (or more unforeseen work !) but when you mention that the royale responded to an ecu swap I was just wondering !.
The area where the Ecu sits is very prone to getting wet .either from a windscreen corner seal leak (easy fix) or the double skinned area behind the front wing a panel / behind the inner wing reinforcement triangle.this rotted on both my senators and Carlton and was a bugger to reach as it's an inside job and quite high up behind the lower dash.(easier on the passenger side thou)
Can be easily checked with a torch from inside the car if needs be.
Just wondered if this was what caused the original ecu to fail .dont want it to happen again to the new one.
Also worth making sure the ecu has a plastic sheet over the top of it anyway (as original) to stop any water drips be them leaks or just good old condensation.
Steve Brookman
  • Blackwood, Gwent
    • Royale/Senator
Re: Senator A2.
« Reply #169 on: 29 July 2018, 09:34:11 »
Thanks Chris-great to hear from you again-how's things?
I haven't noticed any water-but will definitely have a look today as its pouring down.
Regards Steve
Previous
cam.in.head
  • West yorkshire
Re: Senator A2.
« Reply #170 on: 29 July 2018, 10:34:05 »
Hi Steve . Yes I’m fine thanks. Glad you are too .
Yes today is a good time to check for water leaks as last nights downpour should have certainly found them if there were any !
Happy hunting !
Steve Brookman
  • Blackwood, Gwent
    • Royale/Senator
Re: Senator A2.
« Reply #171 on: 30 July 2018, 16:12:20 »
No water!
Had a prod underneath as MOT in a month-found a hole. Will have to practise my MIG welding i think.
Steve
Previous
Re: Senator A2.
« Reply #172 on: 31 July 2018, 07:36:52 »
That will learn you... Incidentally, if that's what the rear chassis rail looks like, expect more of the same at the front :'(
cam.in.head
  • West yorkshire
Re: Senator A2.
« Reply #173 on: 31 July 2018, 18:47:44 »
Hi steve. Common area on senators there although it usually starts on the bottom section that wraps under.(where the handbrake cable passes by).its a double skinned section so a moisture trap.strangely thou i bet the other side of the car is fine !.
Should be a doddle to someone like you thou especially if it is only the side as its easy to work on .
Realy thou to be 100% safe its a fuel tank out job
Never had any issues with senators on the front chassis rails but seen plenty on later carltons.
Steve Brookman
  • Blackwood, Gwent
    • Royale/Senator
Re: Senator A2.
« Reply #174 on: 06 November 2018, 06:40:04 »
Not been online for a while.
Update on vehicles.
Royale not welded yet-had  petrol tank leak-pinhole at bottom-drained and used some petrol tank putty-time will tell if it worked.
Senator out to Aldis on Sunday. Fine on the way-initially started after shopping then cut out. Thought it was the problem I get with it that if it is left for a while after being warm  it takes a lot of cranking to start-usually instantaneous starting when cold (changed everything-ECU, cold start sensor, air flow meter- apart from injectors-could possibly be a leaky injector-or perhaps a s someone said dodgy wiring at the pump).
Tried a few times but not catching.
 Walked home got a few tools (myself included) and went back in the Sierra. Took out plugs-bone dry. Checked fuses and hit relays-still nothing. Got underneath and bashed the fuel pum0p and started immediately.
So new pump and filter ordered. The design on these is crap-the filter comes after the pump-so any shit in the tank hits the pump first.
Steve
Previous
Pages: 1 ... 5 6 7 8 9 10 11 [12]   Go Up
Page created in 0.119 seconds with 21 queries.
